Go Back   Motorized Bicycle: Engine Kit Forum > Bicycle Motor > Norm's 2 stroke repair center
Norm's 2 stroke repair center Having problems with you 2 stroke motorized bicycle engine? Just ask Norm. he loves to tinker and troubleshoot engines.
Old 06-13-2009, 01:20 AM
rockvoice's Avatar
rockvoice rockvoice is offline
Default rings
hey Norm, I was just reading your top end rebuild thread and i was wondering if you could explain (for an idiot) how to remove and replace the piston rings . I have broken a couple trying and im not sure how they are supposed to be positioned and how to slide the jug on.
thanx in advance
Old 06-13-2009, 09:07 AM
toker_ace's Avatar
Default Re: rings
funny. I'm waiting on a new set of rings now.Inside the groves where the rings go, there is a little tit. alighn the opening on the ring with that tit. its funny how easy it slides in the jug. also, someone told me that not all rings are interchangable. Order your rings from whomever you purchased the motor. hope this helps.
Toker has the right idea and some good advice. You can look at the total tear down for the ring info or the top end post I did at least I think thats were it at?! You can look here this might help. http://motorbicycling.com/f39/motori...build-297.html
Norman
