Old 06-12-2009, 11:47 PM
Mikey DEEEE Mikey DEEEE is offline
Default Compression
Is it possible to increase comprerssion and would it be bad for the engine? and can i get a link to smaller sprockets
Old 06-13-2009, 12:42 AM
azbill's Avatar
azbill azbill is offline
Default Re: Compression
yes, maybe
see either creative engineering or kings sales n service
probably others that I can't think of right now
Bill
www.ezmotorbike.com
azgrampa@gmail.com
Old 06-13-2009, 12:50 AM
How would you increase compression
Old 06-13-2009, 01:57 AM
NunyaBidness's Avatar
NunyaBidness NunyaBidness is offline
There are a bunch of threads about compression, a simple search should turn up more than you really want to read.
Old 06-13-2009, 02:23 AM
Dan's Avatar
Dan Dan is offline
Howdy Mikey. I haven't tried it, but seems to have gotten good reviews.
http://motorbicycling.com/f13/new-sl...oost-6621.html
I want 2 ride my bicycle
Old 06-13-2009, 03:24 PM
reg454's Avatar
reg454 reg454 is offline
you could try removing your lower gasket on the jug and use rtv sealant. Just make sure that your piston can move all the way through with out hitting the top if it does you can make a simple cardboard gasket with rtv sealant on both sides of it to give you a little xtra room. I'm running my motor without the gasket and it helps a little bit with compression but I also had to trim the piston skirt (but i did that anway)
