Old 06-12-2009, 08:10 PM
tascott tascott is offline
Default Buying the Right Bike
So here is my issue. I have 2 bikes that the engine won't fit (without major modification) and I had a question for everyone. If I bought a Huffy Cranbrook from wal-mart will my engine from Bike Motor Kits Motorized Bicycles Engine Bike kits work? it's an 80cc engine and if you look at my older threads you will see the problem with my other bikes. Will I have to bend the braking arm on the huffy? If so any suggestions for a good bike that will not require this much work?=
Old 06-12-2009, 09:48 PM
Dave31's Avatar
Dave31 Dave31 is online now
Default Re: Buying the Right Bike
I believe several members have used the cranbrook.
I have built many bikes with coaster brakes, in fact most of them were except for two. It is very easy to bend the brake arm. In fact, many of them I did not have to do anything to the brake arm.
As far as the Huffy? I dont know. Here are some mebers who have built the Cranbrook, you can ask them.
http://motorbicycling.com/f3/first-build-8748.html
http://motorbicycling.com/f15/huffy-...carb-5457.html
http://motorbicycling.com/f15/my-fir...iser-4873.html
Old 06-13-2009, 11:04 AM
wheelbender6's Avatar
Every bike frame has it's quirks when you install a motor. If you clearly post the problem, there are several memebers that will respond with help.
China girl in a 1976 Western Flyer
Old 06-13-2009, 08:13 PM
Cabinfever1977's Avatar
i have a schwinn del mar cruiser and theres no modifications needed with this one.
no bending the brake arm and you take off the wheel dust cap and the sprocket fits on just fine.i used a spacer between the sprocket and wheel and the chain clears the back tire.
i use my tensioner to keep the chain straight with the rear sprocket.
my bike is just like the huffy cranbrook but with fuller fenders and a rear rack.
Old 06-13-2009, 10:40 PM
what brand of engine cabin fever? Mine have no clearance, but problem solved I am using another bike instead... I'll post pictures in a new thread soon, thank you for the input though! It has all helped tremendously.
Old 06-14-2009, 08:15 PM
i have a 48cc dualstart starfire gt-2 grubee from gasbike.net.
my engine is mounted high on frame with 2 rearmounts on rear and metal bracket for front mount. my engine is wider than regular clutch start engines and i still have plenty of clearance,maybe you didnt raise the motor or tilt it enough.
what other bike are you using?
Old 06-16-2009, 09:53 AM
tarstar's Avatar
tarstar tarstar is offline
I baught a ccm ecco steal frame and it seems to be the right fit does anyone have any suggestions ? the back engine frame mount seems fine but the front one barley fits between the two bolts .. should i ben the frame or should i drill through the frame..
N8TIVE
Old 06-16-2009, 01:41 PM
Forbisher Forbisher is offline
Banned
Don't drill your frame..... or bend it
Read.....the answers are all here....its been done before
Mounting Techniques - Bicycle Motor at Motorized Bicycle Forum
You can make a bracket for the front mount
Old 06-16-2009, 02:12 PM
use can make a largeframe adapter plate bracket and u-clamp.
