Old 06-10-2009, 05:53 PM
Eddie Smith Eddie Smith is offline
Default Tas Spitz Deluxe
Yes, thats right I own a Tas QBM-23N. I have it mounted on my SX-200 Pacific Mountain bike. What a treat this thing has really been. I first noticed it when I moved in this old house I got. The motor was mounted on an old bike that was all rusted. I took it off and mounted it on my Bike, of course after I got it running. Come to find out that the motor has very little miles or, hours. I will have some pics for you all soon. Does anyone know if there are diffrant size wheels, or whatever they are called, the little wheel that go's on the tire to make the bike move.
Old 06-11-2009, 05:43 PM
Dave31's Avatar
Dave31 Dave31 is online now
Default Re: Tas Spitz Deluxe
Welcome to the forum, glad you joined us.
Old 06-11-2009, 06:39 PM
Cabinfever1977's Avatar
there called sprockets or pullys and yes they come in diffrent sizes and they will determin your torq and speed.does yours have teeth(sprocket)or no teeth and round with a groove(pully)?
Old 06-11-2009, 06:45 PM
Dave31's Avatar
They are called drive wheels...for the Tas I believe you can use a neoprene high-speed roller skate wheel (62 mm) over the aluminum drive hub.
Old 06-11-2009, 10:27 PM
fodhunter fodhunter is offline
Hello, Eddie Smith..."fodhunter" here, from Prescott Valley, AZ!
I, too, just acquired a Tas Spitz (ebay). Missing a few parts but I think I can find them.
I just like old engines and don't WANT to go faster than 20MPH. on my USA-made Huffy.
fodhunter.
Old 07-30-2009, 12:03 PM
Bikeguy Joe's Avatar
Keep us posted on how you are progressing. I had a Spitz...awesome smooth slow! I liked it, but sold it for a large profit.
Old 08-05-2009, 01:04 AM
msamigo msamigo is offline
Gents:
TAS Spitz, Bike Bug infomration can be found at Bike Bug
Also is our REpair Pointers that might help you in the future.
Mike
Repair Pointers Before Parts Arrive
The literature is $25.
Probably you are going to need a fuel pump kit $25. The rubber diaghram gives out with time and exposure to gasoline. The drive wheel rubber may gone or in good condition. You can tell by looking at it and squeezing it. This hard firm & good shape - OK. If not a new drive wheel is $28.
Newer engine models than yours (I am guessing age of yours) were equipped with a primer pump $25. Engines equipped with it do start easier and the pump will last longer. Plus it gives a method to test the fuel pump is properly installed - the engine block can be busted if the engine is attempted to start with a block full of fuel.
If you plan to mount the engine on a newer model bike (1970 – up) the forks are 5-1/2” wide center to center tan bike forks were in the (1960s). You will need a mounting kit - $15 to spread out the frame of the engine and have the drive wheel run true.
PLEASE DO NOT REMOVE OLD HOSES TO "Carburetor and Fuel Pump" WITHOUT RECEIVING THE LITERATURE FIRST. Fuel lines may be hardened and cracked - you can buy replacements for $5.00 (These do not cause air bubbles problems in the carburetor (which will probably need cleaning to - simple to do - Don't turn adjusting bolt on bottom). Will provide you some tips on doing this that will prevent allot of headaches and repairs in literature.
REPAIRS YOU CAN DO PRIOR TO RECEIVING LITERATURE.
Other than that - what is the condition of the gas tank? If it was drained. It would be good to flush it with a little fresh gas. If not put some bolts & nuts in with some camping fuel (white gas) and shake them it around to knock off the old varnish and rust. If it is badly rusted there are commercial gas tank cleaning kits other folks have used from automobile part stores that work well. I have put some of my old gas tanks in the dishwasher with dish washing power inside - very caustic and will get out rust. Might knock off paint though so you have to make a judgment call on that plus what the wife thinks about that.
An electronic method that works well on some tanks is as follows:
use a power washer to remove all loose rust and sediment. I then fill
the tank with water and add a tablespoon of Arm & Hammer soda for every
gallon of water. Then get a battery charger and connect the positive
(red) terminal to a piece of wire attached to a stainless electrode
(such as a stainless bolt or a stainless spoon) and lower the wire and
electrode into the water making sure it does not touch the bottom or
sides. This is the anode. Then attach the negative terminal to the
tank itself (The cathode). If your charger has a meter, be sure some
current is flowing. Fine bubbles will rise from the stainless anode when
cleaning is in progress. Typical cleaning time for moderately rusted
objects is a few hours. Heavily rusted objects can be left over night.
Then wash the inside of the tank again and dry it out with compressed
air or a hair dryer.
The foot valve in the gas tank may be frozen too. You can free it up with BD Breaker (automobile part stores) after you cut the old felt off. If it does rattle when you shake it - boil it on the stove top in cooking oil (there again - be careful about the wife's opinion on that). You can buy new felt - cut some round holes it and slip it over the valve. If the valve still won't rattle or you can't blow but can suck through it. It may be shot. Have replacements for $15.
You can also check for fire or spark on the engine by taking out the spark plug and turning the drive wheel by hand. 1st look for the spark and if none try the twinkle test by holding the spark plug and turning the drive wheel. If no twinkle then remove the three bolts on the flywheel cover (where starting instructions are posted). Take a 12 or 13 mm socket mounted on a rechargeable drill and turn the engine with it. No spark try a electric cord drill (Be careful doing this). Don’t want to turn the engine too fast without getting everything freed up first.
Old 05-02-2010, 03:10 PM
skypilot's Avatar
skypilot skypilot is offline
Hi, all!
Anybody know where one can get parts to rebuild the fuel line from the primer bulb all
the way into the gas tank, including the clamps?
Old 05-02-2010, 03:11 PM
Dave31's Avatar
Smile Re: Tas Spitz Deluxe
Originally Posted by skypilot View Post
Hi, all!
Have you tried Bike Bug yet?
Old 05-02-2010, 03:39 PM
silverbear's Avatar
silverbear silverbear is offline
EZ Motorbikes Dealer
Hey Mike,
Good to see your post. I'm thinking about firing up the two bug motors which were running when last used. It's been a couple of years since I ran them last. It had been many years of sitting unused before getting them going a few years ago. Thanks to perseverance and your help. They were smooth running little motors. I'll probably sell them when I know they're right. Too many motors and too many bikes. I'll get in touch with you to see about the many unused parts and partial motors I have in a month or so when I'm back home. They're of more use to you than to me.
One of your 'brothers in the wind',
SB
Someday when I grow up I will probably lose interest in toys with wheels, but until then...
