Go Back   Motorized Bicycle: Engine Kit Forum > Bicycle Motor > DIY Home Built Motorized Bicycle (non kit)
DIY Home Built Motorized Bicycle (non kit) Post all about your home built rides here. Weedwacker motors, lawn mower engines ect. This area is for non kit builds
Old 06-09-2009, 12:35 AM
aaronmorg aaronmorg is offline
Default Gear Ratio Questions
I have come to the conclusion that instead of being stubborn and insisting on using an out-dated motor. I will purchase a kit.
Kit = Motorized Bicycle Engine Kits
But there is a small catch:
The only bike I would want to put this kit on has a 20-22" diameter. The kit is made for 24-26" Diameter.
How much trouble would it be to make the engine able to run on this smaller wheel size?
Old 06-09-2009, 01:02 AM
reg454's Avatar
reg454 reg454 is offline
Default Re: Gear Ratio Questions
You would just need to get a smaller sprocket like a 30 tooth should do. The kit comes with a 44tooth sprocket. thatsdax has a few sprockets you can also get custom ones from King's Sales & Service he is a sponser here his sprockets are nice they cost about $37.50 for the amount of teeth you need plus $12.50 for shipping in the US.
Old 06-09-2009, 01:19 AM
Where would I look locally for the sprockets I would need?
Could I get them machined or could i buy them already made?
Old 06-09-2009, 01:33 AM
Pappy's Avatar
Pappy Pappy is offline
You can use a stanard 32T sprocket and have the center hole bored then drill your mounting holes, I have a Schwinn OCC, I used the front sprocket on the rear.
Ride Safe Ride Happy
------------Pappy
http://bicycles4kids.webs.com
Old 06-09-2009, 01:43 AM
Sweet. Thank you
Old 06-09-2009, 03:38 PM
OCCstingray's Avatar
OCCstingray OCCstingray is offline
If you use the front sproket on the rear, the 415 chain would not work with it because the front sproket is for a different size chain. The kit you are getting aaronmorg has the 415 chain.
Old 06-09-2009, 04:19 PM
HoughMade's Avatar
HoughMade HoughMade is offline
Bicycle chain and 415 are both 1/2" pitch. The 415 will work fine with the bicycle sprocket; there will just be some extra side-to-side clearance.
29/10ths cubic inches of raw power.
HoughMade at WIRED.com: http://www.wired.com/cars/coolwheels...memade_bicycle
Old 06-09-2009, 08:17 PM
matt167 matt167 is offline
415 chain is actually designed for use on adult tricycles.. and the front sprocket would be the same as a normal bike, pretty sure anyway..
Old 06-10-2009, 07:21 PM
Sorry about that, I thought they had a different pitch and the 415 chain would not line up with the bicyle sprocket. Good to know that it can work.
