Old 06-07-2009, 11:10 PM
hombremosqa hombremosqa is offline
Default wheels.......what to do now?
ok, so i remember someone mentioning they balanced their wheels, and in my case, i think it would greatly help. so, my question is, how do i do that? the local motorcycle shop wont balance my MB wheels because they are bike wheels, and im sure i can do them myself, but i need help. i dont know what to mount the wheel on, or how to balance them.
any pointers?
oh, and is there a proper way to tighten the bearing nuts?
Old 06-07-2009, 11:23 PM
matt167 matt167 is offline
Default Re: wheels.......what to do now?
stick on wheel weights.. you'll never get it perfect, but the wheels should spin around and never fall with the valve stem on the bottom.. of course improper bearing preload or bearing damage/ improper lubrication will do that too..
just tighten the bearings till they don't rock, then back them off a tiny bit.... My Cranbrooks bearings whined and the coaster brake was mediocor at best.. I pulled it apart, greased it and then adjusted it and the brake got more responsive and whining stopped, this is a brand new bike ( week old now )
Old 06-08-2009, 01:17 AM
Junster's Avatar
Junster Junster is offline
You can also slime the tubes. Once they get spinning they will self balance. It was part of what slime was originally sold for.
Put something FUN between your legs..
Old 06-08-2009, 10:51 PM
DOC BOLM's Avatar
DOC BOLM DOC BOLM is offline
Try this ,go to sheldonbrown.com/gloss The site will tell you how to fix your balance.HD
You never know what you might know,you know
Old 06-09-2009, 02:19 AM
just to note, i have removed the reflectors, and it does run much smoother, as well as adding a front shock to the bike. however, i do still notice the vibration from the front and rear wheels.
thanks for the info, keep it coming!
Old 06-09-2009, 02:25 PM
Bikeguy Joe's Avatar
I ditch the reflectors and wrap the spokes with solder. You can get them pretty close to perfect that way.
Old 06-09-2009, 03:21 PM
Dan's Avatar
Dan Dan is offline
Wow, thats good to know. Do you find it works Junster?
I want 2 ride my bicycle
Old 06-10-2009, 12:30 AM
Junster's Avatar
It worked really well on an old motorcycle I had but on my bike with the motor vibrating I don't think I could tell if the wheels were off or not.
