Go Back   Motorized Bicycle: Engine Kit Forum > Bicycle Motor > DIY Home Built Motorized Bicycle (non kit)
DIY Home Built Motorized Bicycle (non kit) Post all about your home built rides here. Weedwacker motors, lawn mower engines ect. This area is for non kit builds
Old 06-07-2009, 12:17 AM
DeadEye DeadEye is offline
Default Flying Low
A differant sorta build.
Old 06-07-2009, 04:36 PM
theycallmebob theycallmebob is offline
Default Re: Flying Low
HAHA.
Wow, if you make that happen it'll be awesome. Dangerous, yet awesome!
Old 06-07-2009, 11:18 PM
Originally Posted by theycallmebob View Post
HAHA.
The 62cc Zenoah Engine spinning the 24-10 prop should get me about 50# thrust.
I hope for 20 or so mph. The Pitts muffler is set up for smoke so it will be a cool show to zoom by and hit the smoke pump.
Old 06-08-2009, 10:57 AM
Echotraveler Echotraveler is offline
ballons bro!! ballons!!! fly fly !!!!
make a metal harnes and and put some directional flaps on that motor! swamp boat meets china gurl meats the chair with ballons!! DIY ZEPELLIN!!!
Old 08-24-2009, 08:32 AM
squeakmighty squeakmighty is offline
Someone watched UP this morning
Old 08-24-2009, 08:41 AM
Bikeguy Joe's Avatar
So, what ever happened?
Old 08-24-2009, 06:12 PM
TerrontheSnake's Avatar
TerrontheSnake TerrontheSnake is offline
I think someone was killed by a prop and now he's serving time for Manslaughter . No, J/k but really I wanna know too!!
Old 08-25-2009, 10:48 PM
Kevlarr's Avatar
Kevlarr Kevlarr is offline
If you're going to do that do it right and use one of these
SPECS: Displacement: 86cc or 5.25 cid
Bore: 30mm
Stroke: 42.7mm
Horsepower: 7 HP @ 8,500 RPM
Practical RPM: 1,200 to 8,500 RPM
Ignition Style: CDI Automatic Ignition Timing
Weight: 7.11 lbs (3,228 g) with muffler
6.37 lbs (2,892 g) without muffler
Spark Plug: Champion RCJ6Y or RCJ7Y, gap of .6mm (.025")
Propeller Bolt: M10x1.5mm
Magneto Air Gap: .5mm (.020")
Engine mounting holes on rear of crankcase: 6mm (.24")
Overall Length, from back of prop to start shaft end: 197mm (7.75")
Width: 218mm (8.6") Width with plugs. 260mm (10.25")
Overall height: 203mm (8")
Length from back of mount to prop nut: 160mm (6.3")
Height from crank to top of engine: 75mm (3")
and only $800!
lol
Old 09-16-2009, 06:40 PM
Yea I built it and it was SKEERY. The engine came from ebay in good shape but the plug needed replacement and on the first start up it back fired and the prop bolt stripped out, replaced the prop hub and plug and it ran fine.
On take off its a real slug, you have to pedal, then at about 10mph things change, the faster you go the faster it gets. I dont know were it tops out because you got to pull it back as its to fast.
The engine turns about 10,000 rpm and people will stare and stare. Its a real hoot to pass the spandexers screeming 10 grand and blowing air and raw fuel all over them.
Seems I need a velocity stack on the carb as the passing air pulls raw fuel burbling out the carb and through the spinning blades.
The mount has cracked a weld so the project needs work before more testing is done and it needs a differant prop, one thats bigger with less pitch to get a lower geer affect, I am using a 22-18 and would like to try a 24-8
Cheers D.E.
Old 09-16-2009, 08:33 PM
skyl4rk's Avatar
skyl4rk skyl4rk is offline
pics, man, we NEED pics!
Drive fast, take chances.
