Go Back   Motorized Bicycle: Engine Kit Forum > Bicycle Motor > High Performance Bicycle Engine Tips
High Performance Bicycle Engine Tips We all want our bicycle engines to push our bikes faster. Get exclusive engine modification tips and suggestions from us.
Old 06-06-2009, 07:17 PM
reg454's Avatar
reg454 reg454 is offline
Default Cone Making software
If you make of want to make your own expansion chambers this little program willl suit you. Takes 20min off of layout print it up and cut / weld.
I found this free software on the web it's easy and you can print up you cones for making expansion chambers.
Exhaust Pipe Design with Cone Layout Software
Copy and Pasted under this.
If you have ever tried to layout a conic section on sheet metal, cutting just the right piece, that when rolled over and joined on edge, you have a cone with the exact shape, size and angled openings desired, you know it’s not easy. Who might need to do that? If you’re designing an exhaust pipe for your motorcycle project it could come in very handy to get it right the first time with little waste of materials and effort.
Got this link from Andy pointing to a software program
called, amazingly enough, “Cone Layout.” You feed in the dimensions needed for your pipe, diameter, angles and length and the software creates your pattern which can be output in AutoCAD DXF files or encapsulated postscript. Supported units are meter, inch, foot, yard, radians, degrees, gradients, minutes and points. You can print the pattern across multiple sheets of paper if your project is large. It runs on Windows. It even has a minimization routine to find the best place to locate the seam so it can be laid out on the smallest piece of material possible.
This software was initially designed for building an exhaust pipe for a racing motorcycle but people have found a whole lot of other uses since then. A nice little something for your builder’s toolbox.
