Go Back   Motorized Bicycle: Engine Kit Forum > Bicycle Motor > High Performance Bicycle Engine Tips
High Performance Bicycle Engine Tips We all want our bicycle engines to push our bikes faster. Get exclusive engine modification tips and suggestions from us.
Old 05-31-2009, 07:51 PM
dkon0450 dkon0450 is offline
Default gas tank
So i have a basic stretch cruiser...similar to the one at the top of the motobicycling website..and i want to make a gas tank to fit into the area between the engine and the top of the bike. and i was wondering if anyone has any tips befor i start making it.
Old 05-31-2009, 08:56 PM
Bikeguy Joe's Avatar
Default Re: gas tank
Use klegecell foam and fiberglass resin.
Old 06-02-2009, 04:14 AM
Clotho's Avatar
Clotho Clotho is offline
This sounds like an interesting technique. Have you worked with klegecell? What are it's properties?
Thanks for the tip!
Old 06-02-2009, 08:22 AM
ya iv def never worked with klegecell foam or fiberglass....but i guess ill have to learn
Old 06-02-2009, 10:00 AM
Klegecell is almost like "regular" styrofoam, but is fuel proof.
Easy to cut/sand/shape. Reinforce it with fiberglass cloth and polyester resin.
We make airplane fuel tanks with it, and it can be configured to almost any shape or size easily. It's not the cheapest, but there is no substitute. Look for at places like wicks or aircraftspruce.com
Old 06-02-2009, 10:03 AM
Echotraveler Echotraveler is offline
bikeguy joe thats awsome!
Old 06-02-2009, 10:08 AM
You can also use a method where you use klegacell, or other non reactive foam. (can't think of the type right off the top of my head, but they sell it at aircraftspruce.com)
Glue up a few pieces into a block, sand/shape it, then cover it with glass and resin. When you are done, pour some acetone in it to eat away the foam and you have a very light fuel tank that just needs a little putty on the outside for final finishing.
There are other types of resin as well, one is vinyl ester resin I believe.
Aircraft spruce specialties has an AWESOME free catalog that has a lot of good info on types of resin/foam/glues/ect ad nauseum.
Old 06-02-2009, 12:33 PM
Norman's Avatar
Norman Norman is offline
LORD VADER Moderator
you want to use vinyl ester or safety poxy resin some resins will be eaten by gas. I know this for a fact. Joe has it right on molding your tank lots of ways of doing it male or female molds or the mold less way.
Norman
Check out my fiberglass and wood home built airplane I built. VW powered goes 160mph straight and level will do over 200mph in a shallow dive. click on the link to see the plane do a over 200 mph pass on a video
Norman
norms-iron-works.tripod.com
Old 06-02-2009, 01:11 PM
thanks guys helpes alot
Old 06-02-2009, 04:46 PM
Norman's Avatar
I forgot to tell you. Some resins like polyester and vinylester will eat some of the foams so be sure you check to make sure they won't attack the foam your going to use.
Some foams like the beaded foam you can hot wire some foams you should not cut it with a hot wire and some you can't.
Some foams will put out poisonous fumes if you melt, burn, or try to hot wire cut them. The dust made from sanding them will also hurt like yell if you get the dust in your eyes so make sure before you start on this type of project you do the research to work with it safely.
Its lots of fun I think to create things with foam and fiberglass but its lots of work as well.
Aircraft spruce has good info in the catalog on what works with which types of foams and the proper chemicals to use along with the hazards that it can have. So get ready to get dirty!
Do be careful with it as some of the chemicals can eat your hide if you get careless might not happen right away but if you get allergic to it you will break out every time you mess with the uncured chemicals. I got allergic to the resins when I built my airplane and had some sore hands at the last building the wings. Had to stop let them heal up then go at it until they got sore again. At the time I couldn't sure a different chemical got stop my reaction that broke me out. Even now if I mess with that chemical I have to be every careful or I break out.
Norman
