Go Back   Motorized Bicycle: Engine Kit Forum > Motorized Bicycle Mechanical Components > Heads and Cylinders
Heads and Cylinders All about your porting, compression, rings, cylinder and piston modifications to your bicycle engine
Old 05-28-2009, 05:05 PM
HT2005 HT2005 is offline
Default Metal cylinder head gasket
I recently aquired a 70cc chinese engine that didn't have one of those metal gaskets for the cylinder head. I put some orange high-temp silicone stuff as a gasket instead. Anyway, do any of you think this is sufficient, or should I really have that square metal gasket? I'm in no rush, just curious.
Old 06-07-2009, 04:12 PM
impression impression is offline
Default Re: Metal cylinder head gasket
get some of the thinnest aluminum or copper you can find ( .25 or smaller mm ) make a gasket out of it and see how you go.
for a head gasket you want something with a bit of strength.
Old 06-07-2009, 04:31 PM
theycallmebob theycallmebob is offline
I would say you should def. invest in a headgasket, eventually. If it is currently sealed well, then there is nothing to worry about immediately.
However, you can obtain a high quality aftermarket one which will increase you compression for around 8 bucks shipped from Sick Bike Parts.
Or, you could contact you engine supplier and tell them that you are missing one. Odds are they'll drop ship you one immediately.
Either way, I would get one as soon as you can.
Old 06-11-2009, 04:06 PM
Just purchased one from Sick Bike Parts.
