Go Back   Motorized Bicycle: Engine Kit Forum > Bicycle Motor > Norm's 2 stroke repair center
Norm's 2 stroke repair center Having problems with you 2 stroke motorized bicycle engine? Just ask Norm. he loves to tinker and troubleshoot engines.
Old 05-26-2009, 01:40 PM
Norman's Avatar
Norman Norman is offline
LORD VADER Moderator
Default hot rod pusher?
how would you like to build one from this?
alcohol burning briggs very hot cam it will turn 9000 rpms and a racing slick.
The clutch I use for this ingauges at 3600rpm the max rpm a normal biggs redlines at.
the noise from this exhaust will make you go deaf! It also drinks fuel like to tomorrow!
its an alcoholic engine!
norms-iron-works.tripod.com
Old 05-27-2009, 01:41 PM
Ilikeabikea's Avatar
Default Re: hot rod pusher?
Build it Norm, It'd be cool for sure....................
Old 05-29-2009, 02:20 PM
Echotraveler Echotraveler is offline
that would ROCK!!!! looks like a very nice wheel!
Old 05-30-2009, 01:05 AM
Goat Herder's Avatar
Gutter Rider
You tube it! Would love to see it in action!!
Old 05-30-2009, 09:04 AM
Norman's Avatar
Not me! It would require me to chop up an axle to make they are not cheap if I had a bent axle I would consider it. I'd probably run the less hot alcohol engine this thing needs to be rebuilt after the race day it wears quickly turning the high rpm. at least inspected to keep it fresh turning an engine twice it normal rpm shortens it life. I'd make everyone in the neighborhood mad at the noise
it will make I did the picture as more of a joke than an idea to really build. I wanted to see what you guys would say.
Norman
Old 05-31-2009, 03:53 PM
OzzyU812's Avatar
OzzyU812 OzzyU812 is offline
Norman
Don't get our hopes up like that Norm.
DAX 80f
Slanthead
NGK B7HS
SBP performance wire
44T
Stock Exhaust
32:1 cheap oil
no port matching
30 mph uphill!!!
