Go Back   Motorized Bicycle: Engine Kit Forum > Bicycle Motor > Norm's 2 stroke repair center
Norm's 2 stroke repair center Having problems with you 2 stroke motorized bicycle engine? Just ask Norm. he loves to tinker and troubleshoot engines.
Old 05-26-2009, 01:20 PM
joe-craft's Avatar
joe-craft joe-craft is offline
Default Carb Jets
hi i have a stock carb from a PK-80cc limited engine kit and i accidently upped the size with a #60 drill bit, so i orders these, just wondering if anyone thinks they will work with this carb
Mini Pocket Bike Performance Carburetor Jets 47cc 49cc - (eBay.ca item 170334539278 end time 19-Jun-09 00:45:18 EDT)
Old 05-26-2009, 01:25 PM
Pablo's Avatar
Pablo Pablo is offline
Default Re: Carb Jets
What thread size are they?
Old 05-26-2009, 01:29 PM
Norman's Avatar
Norman Norman is offline
LORD VADER Moderator
Joe
If they will fit the carb then I think they will work ok the threads size on the jet and the jet dia might be right I don't know just looking at them. You could solder your jet shut and re drill it yourself I use a 0.027 dia drill in a hand held pin vice to drill mine. I use a propane torch and acid flux solder you can use resin core solder as well its pretty easy to do and don't take but a few seconds to do. The jets aren't cheap I see.
Norman
norms-iron-works.tripod.com
Old 05-26-2009, 01:54 PM
joe-craft's Avatar
hi i cant drill or solder them due to the fact that i dont have any drill bits that small, and to get one i have to wait a month for the company to get them in, and the machine shop in my toen only goes down to a #66 drill bit, also it would be cheaper for me to get these in any cause, so either way im stuck. also im getting an email from the dealer about the jets and getting the standard size of them.
Old 05-26-2009, 04:16 PM
Pablo's Avatar
In general I see 5mm THREAD and 6mm THREAD jets.
The stock Chinese carb takes the smaller 5mm THREAD JETS.
Like zeeze: Main Jets 5mm : Dellorto Carburetors, And parts for you.
Old 05-26-2009, 08:17 PM
theycallmebob theycallmebob is offline
Those screw right in and work as an OEM replacement? No hassle?
Old 05-26-2009, 08:29 PM
Pablo's Avatar
yep bob'syeruncle!!
Old 05-26-2009, 08:36 PM
Goat Herder's Avatar
Gutter Rider
Harber freight had a great bit set Item 94606 only 3 bucks! They go down to a hair LOL.
Old 05-26-2009, 10:51 PM
yep bob'syeruncle!!
Well slap me in the butt and call me bobby!
Thanks as usual Pablo, most informative. Back to the OP question.
Old 05-27-2009, 11:30 AM
joe-craft's Avatar
thanks everyone for your help, my jet shipped out this morning so ill probably have them by friday or monday at the lastest. also today im picking up my 3-speed internally geared hub that i found for $30 tax-in. ill have to get it spoked on a rim but ill get that done later down the road.
