Old 05-26-2009, 01:10 PM
Bikedad1's Avatar
Bikedad1 Bikedad1 is offline
Default New engine inspection
Have any of you guys come up with a good pre-run check list for these motors? I feel like I should give it a good look before I try to run it............
Old 05-26-2009, 01:28 PM
cabbiex5 cabbiex5 is offline
Default Re: New engine inspection
http://motorbicycling.com/f30/bicycl...-care-354.html
Old 05-26-2009, 01:48 PM
Bikedad1's Avatar
Thanks for the info...................this hobby has the coolest people in it.
Old 05-27-2009, 12:29 AM
OzzyU812's Avatar
OzzyU812 OzzyU812 is offline
hobby? obsession
DAX 80f
Slanthead
NGK B7HS
SBP performance wire
44T
Stock Exhaust
32:1 cheap oil
no port matching
30 mph uphill!!!
Old 05-27-2009, 06:02 PM
Bikedad1's Avatar
Its already become an obsession in a short amount of time..........I was already a bicycle freak so it wasnt to far of a jump for me.........LOL
Old 05-28-2009, 11:55 PM
Cabinfever1977's Avatar
yeah check your gas tank nuts and mounting studs. my gas tank nuts fell off and one of my rear engine mounts fell out and the engine stayed on my bike all the way home and i retightened everything.
Old 05-30-2009, 05:18 PM
GMulhollan's Avatar
GMulhollan GMulhollan is offline
Exclamation Re: New engine inspection
I have to second inspecting the mounting studs. My engine mounting studs were bent upon arrival. I took this as a sign to get them out. I removed front/rear and exhaust studs. Interestingly the exhaust studs had the cad-plate look to them and were the only ones that had some thread lock on them. I got a stick of high grade 6x1mm threaded rod at my bolt shop and this weekend it will be transformed into 6 studs. If you do this, don't forget to dress the ends (file or grind). I find that running a new nut over the end lets me feel any bad spots. Then, clean, add a little thread lock and install. Best metal on the engine!
Old 05-30-2009, 06:48 PM
Bikedad1's Avatar
I have decided to replace the studs and I already checked for gasket interference and wow the really stuck out into the intake port! I got one of those Creative Engineering clutch kits and a sprocket adapter. I should be done soon!
