Go Back   Motorized Bicycle: Engine Kit Forum > Bicycle Motor > Norm's 2 stroke repair center
Norm's 2 stroke repair center Having problems with you 2 stroke motorized bicycle engine? Just ask Norm. he loves to tinker and troubleshoot engines.
Old 05-26-2009, 11:00 AM
Pablo's Avatar
Pablo Pablo is online now
Default Clutch guts part II
NORMAN - have you posted any photos or drawings of adjusting the (strong) internal spring for the clutch? This spring actually controls clamping force as you have said before. From what I read, it can be accessed from the left side (with the sprocket removed) - with a flat screwdriver
This mystical spring has been seen in exploded views, and had been mentioned in a thread or two. But a Norman adjustment tutelage with pictorial aides would nice. Thanks!
Old 05-26-2009, 12:05 PM
Norman's Avatar
Norman Norman is offline
LORD VADER Moderator
Default Re: Clutch guts part II
Jim from creative engineering did a post on that if you take the clutch cable mount off/ out of the engine you can access that slotted spring retainer hold the blade of the screw driver in one of the slots and crank the gear shaft on the rear sprocket side to the right to put more pressure on the spring if I remember right shouldn't take much to make it loaded up more on pressure all of the screws nut etc on these engines are right hand threads at least the one I've worked on are that way.
I could do a picture how to might be a good idea I'll see what I can do.
Norman
Pablo per your request I'm got the pictures now I need to do the posts.
How to adjust your real clutch spring with out taking the engine apart.
norms-iron-works.tripod.com
Last edited by Norman; 05-26-2009 at 12:53 PM. Reason: darn it Pablo you made me have to work before noon
Old 05-26-2009, 01:07 PM
Pablo's Avatar
Haha sorry. Thanks!!
Old 05-26-2009, 01:23 PM
Norman's Avatar
No problem.
Norman
Old 05-26-2009, 01:57 PM
Bikeguy Joe's Avatar
http://motorbicycling.com/f3/externa...ring-4851.html
page 2 of Jims post link#14
Old 05-26-2009, 02:50 PM
Pablo's Avatar
Wow - missed that one. Jim's is all about making it looser. (same concept!!)
