Re: Whos blown a motor ?
leaner fuel to oil mixture or lean fuel to air mixture?
Mine died today not from running lean in any way just old age, she was singing along flat out and just lost power but i was able to putt home, just.
On inspection i thought i had turned the keyway but all was good. off with the head and barrel i found a deep groove down the barrel and the piston had a heap of extra play in every direction. strip piston off and the gudgen bush has a huge piece missing where did it go? welded itself in the piston rings and welded them shut! and stuffed the barrel, the loss of power. cheap fix!
alot of porting to do again!
steve
