Old 05-22-2009, 10:45 PM
35oriano 35oriano is offline
Unhappy Mag Rims need help!!
Hello,
I am new to this forum, and I just started on my first bike this past month. I got everything running and going well, then I decided to switch to mag rims. I figured I could attach the sprocket to the rim directly they look cool, and all that good stuff. I got the front tire mounted and then I went to put the rear one and I noticed that it is to wide to fit into my cruiser frame. If anyone attempted, and/ or succeeded please advise me on what to do.
I appreciate any help.
Thanks,
35oriano
Old 05-22-2009, 11:04 PM
Clotho's Avatar
Clotho Clotho is offline
Default Re: Mag Rims need help!!
I would like to help but without pictures, measurements etc. there is no way of knowing what the problem is and how it might be remedied. Which mag rims are you refering to? What type of bike? How wide is too wide?
Old 05-23-2009, 02:52 AM
Clotho's Avatar
Without being able to see your frame and wheel myself it is a bit of a guess. Still, 1 inch sounds doable with the right tools. (no guarantees, proceed at your own risk!) In the ideal situation you would try something like this: Frame spreader tool to separate the rear dropouts and make enough room for your new rim. You have to be careful not to spread them too much however as you will damage the frame. You don't necessarily have to order a tool for this specific task. a length of ready-rod, a handful of nuts and a couple of washers would do the trick too. Then there is always the brute force approach as well. A scissor jack between the dropouts could work too. Just be careful.
Old 05-23-2009, 12:56 PM
Finfan's Avatar
Finfan Finfan is offline
BTW you now have 3 posts to your count. You should finally be able to post that picture!
-and-
I'm not lost, I'm exploring!
Old 05-23-2009, 01:01 PM
Thanks, guys I actually used the scissor jack to spread apart the frame. It worked so I am in the clear for now till another problem arises.
Thanks
Old 05-23-2009, 07:24 PM
Cabinfever1977's Avatar
goodluck with your build,glad it worked out with your wheel.
Old 05-26-2009, 04:50 PM
Thanks for all the help. Here is a picture of my bike with the mags on.
Old 05-26-2009, 05:50 PM
skjjoe's Avatar
skjjoe skjjoe is offline
Thumbs up Re: Mag Rims need help!!
looks real nice what tank is that.very cool looking
stay thirsty my friends
Old 05-26-2009, 10:05 PM
Thanks, My friend had an old moped he wasn't using so he gave it to me. The tunnel is pretty wide on it though there's like a 3/4" gap on the top tube of the bike though.
Old 05-26-2009, 10:40 PM
skjjoe's Avatar
I used hot water pipe wrap to take up the space and dampen the vibration a little .Just wrap your top tube in it then put the tank on
