Re: Air leak in carb?
Drilling extra holes in the air cleaner cover is not the same as having air enter through an opening in the intake manifold or other areas. Too much air being drawn into the engine downsteam of the carb makes for a lean condition, (too much air to fuel mix) and can eventually damage an engine. Opening up the air cleaner cover will, supposedly, allow more air, or at least reduce the restriction imposed by the cover. To be honest I tried holes in the cover and could tell no difference in engine performance whatsoever. The engine can only take in so much air, as dictated by carb throat size, crankcase design and vacuum and cylinder effeciency, so extra holes will not give you added performance.
Port matching, ei, exhaust flange to cylinder and intake manifold flange to cylinder is one way to gain a little power but don't expect wheel standing performance gains. Hope this helps a little.
