Old 05-17-2009, 08:32 PM
kaguil kaguil is offline
Question no vacuum please help!
ok so I got my 80cc bike checked by a professional he says it has gas, and it has spark but it still doesn't start and then he said it might be because there is no vacuum but I don't know how to fix it please help the weathers getting so nice and i want to ride it.
Old 05-17-2009, 08:46 PM
Pablo's Avatar
Pablo Pablo is offline
Default Re: no vacuum please help!
No compression? Head nuts loose?
No "vacuum" could mean what we call an air leak...do a search for air leak.
Old 05-17-2009, 08:53 PM
toytime toytime is offline
I think you have to start at the most common problems and work your way through. I have no idea what the guy is talking about as far as vacuum goes.
If it were me, I'd make sure that the wires are hooked up properly. You need to tell us things like how the kill switch wired up. Many members, including myself have spent hours figuring out that it was just a stupid wiring or switch problem.
The spark plugs that come with the kits are not the best and a spark plug can fail when under compression, you should try another one.
Are you giving it choke and 'tickling the carb" with that button on the left side of the carb? Is this a new kit? Need more info!
Old 05-17-2009, 09:59 PM
spad4me's Avatar
spad4me spad4me is offline
He didn't just pull the plug wire and let it spark away? This equals destroyed cdi.
Does it have a fuel oil mix in the tank?
Is the proper amount of fuel oil mix being delivered to the engine?
Find a long down hill run.
open the petcock , on the bottom of the fuel tank ---lever straight down.
Push the tickler button located on the left top of the carb..
push it down gently a couple of times.
Choke lever located on the right of the carb .
place it halfway between up and down.. in the middle.
On the top of that long downhill run .
start peddaling with the clutch pulled in . No gas leave the throttle alone.
When you are going faster than walking speed pop the clutch and keep peddaling until it starts.
Just a thought pull the air cleaner and look in he carb while twisting the throttle does the slide move up and down
Motorized bicyclist
Old 05-17-2009, 10:43 PM
skyliner skyliner is offline
try a ngk b6hs plug
if you dont see smoke your doin somthing wrong fly low beat the radar
04 shcwinn 80cc dax sbp camber cns carb boost bottle k&n filter 36 tooth 40mph (gps tested) havin fun and smokin scooters
Old 05-18-2009, 06:47 AM
deacon's Avatar
deacon deacon is offline
minor bike philosopher
Most likely it is an air leak at the carb intake.... Make sure you have either used a sealant or an "0" ring at the bottom of the connection... That is by far the most common problem if it has spark and gas....
Old 05-18-2009, 11:53 PM
OK sweet i will try all of your suggestions, man i love this site ill be back with updates probably somewhere in the weekend
Old 05-25-2009, 03:59 PM
Norman's Avatar
Norman Norman is offline
LORD VADER Moderator
no vacuum might mean the clutch is slipping= no piston movement = no vacuum. can you hear the piston pumping as you try to pedal start it?
Norman
norms-iron-works.tripod.com
