Old 05-17-2009, 06:02 PM
FatManChan FatManChan is offline
Default Shortening chain
Is there any way to take chain links off other than a chain tool?
Old 05-17-2009, 06:18 PM
Outrunner's Avatar
Outrunner Outrunner is offline
Default Re: Shortening chain
Sure, Just use a Dremel tool with a stone and grind both pins
on one side of the link, take a punch or pry the link apart.
Old 05-17-2009, 06:23 PM
bk_punisher bk_punisher is offline
hello. i did the same thing but with out the dremel. i just vised it then got the punch. once you get it moving your home free.
Old 05-17-2009, 07:13 PM
I don't own a dremel so I'll just buy a multi-tool from the local bike store that comes with a chain tool. Thanks for the help guys
Old 05-17-2009, 07:21 PM
misteright1_99's Avatar
I just laid mine flat on a piece of wood, and struck it with a punch/ awl and drove the pin out.......
"No such thing as a stupid question, just a stupid answer"
48cc Grubee Starfire Round Head......
Old 05-17-2009, 09:45 PM
OzzyU812's Avatar
OzzyU812 OzzyU812 is offline
adding to that drill a small hole in the wood so the pin has a place to go
if anyone asks what you want for x-mass or b-day say Dremel!
DAX 80f
Slanthead
NGK B7HS
SBP performance wire
44T
Stock Exhaust
32:1 cheap oil
no port matching
30 mph uphill!!!
Old 05-18-2009, 07:31 PM
Cabinfever1977's Avatar
i used a jigsaw and pliers and a master link.
Old 05-19-2009, 12:23 PM
Finfan's Avatar
Finfan Finfan is offline
The chain tool for a bicycle chain is too light weigh for the 415 roller chain. It will probably break!
-and-
I'm not lost, I'm exploring!
Old 05-19-2009, 01:26 PM
HoughMade's Avatar
HoughMade HoughMade is offline
I have a Dremel...and I would not think of grinding a pin. First, it is not necessary. A punch is all you need. Second, if you do not grind, you can refuse the link and pin if you want to- with grinding, you risk the pin working out over time.
29/10ths cubic inches of raw power.
HoughMade at WIRED.com: http://www.wired.com/cars/coolwheels...memade_bicycle
