| Motorized Bicycle Trouble Shooting Use this area to post problems that may arise that you could use some help in figuring out what is wrong with their bicycle motor and what needs to be done to achieve top performance. |
05-16-2009, 05:01 PM
New 80cc engine, no gas to spark plug
Hey Guys,
I just attempted my first bicycle engine kit and can't get it started. I can't see or smell any gas getting to the spark plug. I have gas flow to the carberator. I have taken apart the carberator and all seems to be working properly. The throttle is working as it should. I've sprayed starter fluid in the spark plug and the engine wants to start, so I should be getting spark. I have tried for about 4 hours to get it started and am at a dead end.
Any suggestions would be greatly appreciated. Thanks
05-16-2009, 05:17 PM
Re: New 80cc engine, no gas to spark plug
hey ken, although you see the fuel line is full and reaching the carb it's important that the float is operating properly, if it's stuck you may find the bowl dry or very little fuel. Also that the inlet has no obstructions. Pull the bowl and double check. good luck
Nothing runs like a deere
05-16-2009, 06:09 PM
I am not sure where the float is located. Is it on the top of the carberator? i know there is a white circular plastic piece at the top of the carberator and it is bone dry. There is probably some sort of obstruction but im not sure how to check it. Thanks for your help!
05-16-2009, 06:11 PM
That white circular thing is the float, and it should not be dry in there. Give me a minute I will get some pics 4 ya.
05-16-2009, 06:20 PM
Well shoot! I lost my carb pics, you will just have to use Normans pics.
http://motorbicycling.com/f39/motori...build-302.html
Look at post #9 I believe...got 2 go the race is going to start, hopefully someone else will have the time to explain it better.
05-16-2009, 08:32 PM
If you remove the float bowl (bottom of the carb) and there is some gasoline in there, you may have a problem with an air leak. Sometimes the gasket between the engine and the intake tube is bad (seal it with silicone, Seal All, or gasket maker).
05-16-2009, 08:33 PM
Did you say you had your float on top of the carburator? Do you have it put upside down...?
05-16-2009, 08:36 PM
That's what I was wondering....that would definitely cause some problems.
05-17-2009, 06:33 PM
thanks guys, the carb was upsidedown. I got it started today. I really appreciate all your help!
05-17-2009, 10:35 PM
wow upside down huh good luck chuck
| Thread Tools |
| Display Modes |
Linear Mode
