Old 05-16-2009, 03:45 PM
Mikey DEEEE Mikey DEEEE is offline
Default keyed ignition
is it possible to have a key ignition on a motorized bike?
Old 05-16-2009, 04:05 PM
philymitch's Avatar
philymitch philymitch is offline
Default Re: keyed ignition
Here is what I found. Mounting it might be the hard part.
Ignition Module (Key Switch) with Keys - 2 Wire
Old 05-16-2009, 04:32 PM
now will this work with a raw 80cc motor?
Old 05-16-2009, 06:48 PM
philymitch's Avatar
You would just cut the blue wire from the motor so you have two ends. Then one blue to one white and one blue to one white. Like an inline fuse it would work
Old 05-16-2009, 06:58 PM
i would still want the kill switch to work though
Old 05-16-2009, 06:59 PM
philymitch's Avatar
here is the lay out
Old 05-16-2009, 07:03 PM
would the kill switch still work? can i do it without cutting wires?
Old 05-16-2009, 07:06 PM
marvin martian's Avatar
marvin martian marvin martian is offline
I don't know how to make a link to e-bay, but here is the item number of a switch that has cooler looking keys. It is the same one I used on my bike, it has 2 sets of contacts.
Item number: 370200032345
Old 05-16-2009, 07:30 PM
Finfan's Avatar
Finfan Finfan is offline
With all the wires exposed to the outside world what is the point? It would take less than a minute to bypass the key switch. You still have to lock it up or they'll take off with it even if it is just pedaling. You gain nothing by adding the key. Just a thought.
-and-
I'm not lost, I'm exploring!
Old 05-16-2009, 07:41 PM
i would still lock it upi wouldnt want people to start the engine
