Old 05-15-2009, 09:11 AM
Mikey DEEEE Mikey DEEEE is offline
Default Bike takes a while to start
Hi, im michael from AZ and when i start my bike it starts stuttering and it takes a while to start can i get some help with this?
Edit/Delete Message
Old 05-15-2009, 09:15 AM
budwiseradam's Avatar
budwiseradam budwiseradam is offline
Default Re: Bike takes a while to start
man i wish i could help ,,,,id be happy if mine ran at all , you still have a stock parts? more info might help
<embed src=http://img366.imageshack.us/img366/7788/budwiseradamsigmq1.swf width="455" height="200"></embed>
Old 05-15-2009, 09:16 AM
i just got the motor installed a few days ago, i do have all stock parts
Old 05-15-2009, 09:19 AM
when i pedal it starts but i have to rev it up to get going idk why also i cant idle u think my cable needs to be tightened, any ideas?
oylavabeer oylavabeer is offline
try the choke
Old 05-15-2009, 10:03 AM
Bikeguy Joe's Avatar
Turn the screw IN on the left side of the carb. It is for idle speed, not mixture, despite what the "instructions" say.
Let us know if that helps.
Old 05-15-2009, 10:05 AM
Push the tickler button on the left side of the carb, pull the choke 1/2 to 3/4 of the way UP pedal and release the clutch with the throttle just cracked open and as it warms up a bit, push the choke back down.
I always fire mine up, and ride it slowly to warm it up. I don't start it and then try to let it idle to warm it up.
Old 05-15-2009, 11:34 AM
thank you all so much
Old 05-15-2009, 11:37 AM
ohh last question, what is the difference between a boost bottle and a nos kit?
Old 05-15-2009, 12:25 PM
One will blow your engine if set up correctly, the other doesn't do anything but boost the money from your wallet when set up.
