Old 05-14-2009, 11:50 PM
mycam8u2's Avatar
mycam8u2 mycam8u2 is offline
Default seat post and handlebar stem
my seat post measures 1 inch and my stem meas. 7/8. just wondering what the metris fquivalent is on those..also when measurind the handle bar do i measure the tube or the actual part that fits inside the stem? thanx for any help
Old 05-15-2009, 12:12 AM
Finfan's Avatar
Finfan Finfan is offline
Default Re: seat post and handlebar stem
One inch is just over 25mm, 7/8" is just slightly over 22mm.
-and-
I'm not lost, I'm exploring!
Old 08-23-2009, 08:54 PM
motorhedfred's Avatar
motorhedfred motorhedfred is offline
Remember the number 25.4 Divide millimeters by 25.4 to get inches. Multiply inches by 25.4 to get millimeters. Remember, inches must be converted to decimals. Example.....
1 1/8" = 1.125 inches 1.125 times 25.4 = 28.575 28.575 millimeters
33mm divided by 25.4 = 1.2992125984251968503937007874016 for all intents and purposes 1.3 inches
Old 08-24-2009, 12:32 AM
Kevlarr's Avatar
Kevlarr Kevlarr is offline
AAAAKKKKK! MATH!
I just use Online Conversion - Common Length Conversions
Old 08-25-2009, 07:35 PM
restapukin restapukin is offline
yeah, if anyone's interested, an imperial lathe (with it's orig imperial gearset) is well able to cut near-enough metric threads - i can't remember the tolerances except to say that no further investment on gearing would be required for pretty much any motorcycle work at all - the 'near enough' tolerances of an imperial lathe/std gearset turn out to be very very close indeed in theory & well and truly close enough for real-world practical purposes...
just in case anyone's thinking of buying an engineer's lathe
heck of a lot of milling ops can be done on the lathe too...
innit .... anyhow....
Old 08-25-2009, 07:42 PM
bandito bandito is offline
Whats the Imperial system? Sounds like sumtin to measure the queens boobs with. In American its called S.A.E
Old 08-25-2009, 10:22 PM
Imperial measures - feet, inches, M.P.H. pounds, ounces; ....
Metric measures - grams kilos; millimetres, centimetres, metres
pretty mainstream stuff...
the world went metric a long time ago
The british isles dragged their feet...
The U.S. are still dragging their rear quarters you might say.
Swimming pools are the exception in the states, i have heared...
Old 08-25-2009, 10:32 PM
must be a load of old lathes going cheap around the north east 'states
Main thing to check would be the main head bearing... but i'm a rank amateur thinking used car used bike used lathe ... & all day to fool around
