Old 05-14-2009, 09:54 AM
mycam8u2's Avatar
mycam8u2 mycam8u2 is offline
Default centrifugal clutch
where is the cheapest place to get a centr. clutch from? and do u have to have a pullstart to start it or can u still start it w/ the pedals? oh does anyone know if the old style horeshoe looking brake calipers work with fenders?
Old 05-14-2009, 10:12 AM
OzzyU812's Avatar
OzzyU812 OzzyU812 is offline
Default Re: centrifugal clutch
You have to have a pull start to start it. That is what is keeping my away from them. Those things stink on mower, on bike motors they are worse from what I here.
DAX 80f
Slanthead
NGK B7HS
SBP performance wire
44T
Stock Exhaust
32:1 cheap oil
no port matching
30 mph uphill!!!
Old 05-14-2009, 10:17 AM
HseLoMein HseLoMein is offline
There is a vendor that sells a cent clutch witha one way bbearing so you can still pedal start, I dotn think its the one i have, but im not going to install it now that my pull start failed
Old 05-14-2009, 10:38 AM
OzzyU812's Avatar
Who has the CF clutch you can pedal start?
DAX 80f
Slanthead
NGK B7HS
44T
Stock Exhaust
32:1 cheap oil
no port matching
30 mph uphill!!!
Old 05-14-2009, 10:49 AM
kitimatflyer's Avatar
kitimatflyer kitimatflyer is offline
Zoombicyles have them and yes you can petal start them
Old 05-14-2009, 10:52 AM
mycam8u2's Avatar
thanx, i looked on zoom earlier this morn, just wanted to know if u can pedal start, thanx again for all the help
Old 05-14-2009, 10:53 AM
lordoflightaz's Avatar
lordoflightaz lordoflightaz is offline
It's on the Grubee engine it will be called something and GGG-2 which is pull start and pedal start. I don't know what parts you would need to retro fit it onto an engine.
Map your motorized bikes location on a Frappr Map show us where you are and post a pic of your bike.
If trailer parks didn't exist would tornadoes exist?
Old 05-14-2009, 07:09 PM
eDJ's Avatar
eDJ eDJ is offline
I saw the one at Grubee a couple months ago myself. As I'm researching this stuff
constantly I wondered how they got the centrifugal to dual start. I figure in time
it will be quite popular as it would make it more user friendly for women.
mycam8u2
Yeah those brakes have been fitted on bikes with fenders for years now. It's not a
problem.
Old 05-14-2009, 09:13 PM
mycam8u2's Avatar
thanx for all the help guys
Old 05-14-2009, 09:52 PM
Cabinfever1977's Avatar
my 48cc dualstart starfire gt-2 grubee from gasbike.net
has manual and centrifugal clutch,can be peddal or pullstarted
Dual GGG model; Allows pedal starting as well as rope pull engine start. Uses a friction clutch as well as a special centrifugal clutch with over running clutch lock up to pedal start; Handle Bar Clutch lever must be in the engaged position to operate in centrifugal clutch drive mode. In disengaged lever position the engine is in free wheel mode separated from drive line. Note: A standard friction clutch engine can not be converted to GGG dual mode due to different crankshaft
