| 2 Stroke Bicycle Engines & Kits 2 stroke motorized bicycle engine kits need careful installation and setup, find out how from our professionals here! |
05-14-2009, 02:41 AM
throttle trouble...again
I just finished installing a clutch actuator I got from Creative Engineering/Manic Mechanic. The clutch seems to work ok as far as disengaging and the start of the engine is actually a lot smoother now.
(Kudos to Jim for his great work!)
The problem is I seem to be having problems with the throttle again. The clutch seems to work fine: when I disengage it, the engine starts to turn over. This works, but twisting the throttle doesn't seem to engage the engine.
I can hear revving sounds inside the engine as if something is happening, but this isn't increasing my throttle at all.
I went through all of the standard steps in starting an engine, I even tried to start going downhill. The engine seems to turn over fine, but no luck with the throttle.
Might something be loose in the carb? Do I need to check the cable connection on the twist throttle handle?
Other than change out the clutch, and rewire the factory kill switch, I've not made any modifications to the setup. The engine was working just fine before this. I had no problems with actually running the bike.
Here's my setup: standard 48cc HT kit on a schwinn point beach. I spliced the black wire of my kill switch with the black wires from the CDI and the engine. I wired the yellow wire of my kill switch to the blue wires of my CDI and engine. I capped the white wire coming out of the engine.
Adjusting the choke seemed to have no effect on this throttle problem. The cable seems to be pulling correctly on the stuff inside in the carb, but for whatever reason, it's not engaging the throttle.
My engine eventually comes to a stall on me.
Any help with the troubleshooting would be much appreciated.
Thanks in advance!
05-14-2009, 08:30 AM
Re: throttle trouble...again
So are you saying it won't start? Or it starts but when you twist the throttle the engine rpm's do not increase?
05-14-2009, 08:33 AM
The engine starts, but twisting the throttle doesn't seem to increase the speed of the engine. I hear some revving sounds like something is working, but I can't seem to get any throttle at all.
05-14-2009, 08:37 AM
OK, first step is to remove the carb and air filter off the carb. Leave the throttle cable hooked up. Look down the intake of the carb and twist the throttle on your bars. Is the slide moving up and down when you twist the throttle. Is the little pin also moving up and down with the slide?
05-14-2009, 09:50 AM
LORD VADER Moderator
Where in New Mexico do you live I live in the Texas Panhandle.
http://motorbicycling.com/f39/motori...build-302.html this might help if you look through it shows how to put the carb togetheer look at permalink #5
Norman
05-14-2009, 10:17 AM
I live in the northwest corner.
Thanks for the link. I'm going to go try this right now.
05-14-2009, 11:07 AM
check your exhaust to see if its blocked.
its only too fast if you cant stay on!
05-14-2009, 11:36 AM
The slide seems to be moving when I twist the throttle. I am going to check the intake and exhaust to see that they are not clogged and post the results of that.
05-14-2009, 11:43 AM
Just a note, the pin is moving as well.
05-14-2009, 12:43 PM
Motor Seems To Rev Up,but No Increase In Speed? Clutch Slipping? Ron
PUMP YOUR BRAKES  HAVE TO LOVE WINDOWS & THE INTERNET
NEVER BEAT ON IT, GET A BIGGER HAMMER
"A MAN WHO SAY`S IT CANNOT BE DONE SHOULD NOT INTERRUPT A MAN DOING IT"
| Thread Tools |
| Display Modes |
Linear Mode
