Go Back   Motorized Bicycle: Engine Kit Forum > Bicycle Motor > Mounting Techniques
Mounting Techniques Every frame is different. Share and ask questions about mounting your motorized bicycle engine kit to your bicycle frame or bicycle rack
Old 05-12-2009, 07:03 PM
Bikedad1's Avatar
Bikedad1 Bikedad1 is offline
Default Better motor mounts
How do I get some mounts like these without paying $174?
Ridley Motorcycle Co. - Motor Mount Kit
Old 05-12-2009, 09:53 PM
Cabinfever1977's Avatar
Default Re: Better motor mounts
you can make them yourself,or someone on here mite make them for you for less than that,just ask around.
Old 05-13-2009, 12:03 AM
BrettMavriK's Avatar
BrettMavriK BrettMavriK is offline
Contact Jim " Creative Engineering "http://motorbicycling.com/members/creative-engineering/
http://s90.photobucket.com/albums/k2...h_IMG00208.jpg
My Production Bobber Build Up
'BrettMavriK
"Everything Is Possible...If You Can See Beyond The Invisible"
Old 05-25-2009, 11:58 PM
floridaboy's Avatar
floridaboy floridaboy is offline
Yes by all means get ahold of Jim and let him make you a motor mount for your bike . Jim has made two sets for me when i took the bikes down to him and they are working great. Also check out his sprocket adaptor and sprockets. He can make about and size you would need. His work is top notch.
Old 05-26-2009, 09:50 PM
2door's Avatar
2door 2door is offline
Are you a welder? Do you have metal fabrication skillls? If yes, make them yourself. Mounts are not hard to make but some talent and imagination is involved. If you're not comfortable with doing them yourself then the advice above is good. Check out Creative Engineering for an installation kit that will make motor mounting easy and secure. MANIC Mechanic Parts.htm
Old 05-27-2009, 08:56 PM
Bikedad1's Avatar
I have the skills just lack the tools and I have already ordered the clutch kit and sprocket adapter from Jim. I guess I should query him about a motor mount
Old 05-30-2009, 12:12 PM
Yes, you can make them yourself if you have the tools, and they can have rubber isolation points to all but remove the engine's 'nad rattling harmonic vibrations from the frame. I'm designing a prototype set out of steel for the new bobber frame I am producing. These will also swivel, so this way you can "clock" the engine exactly where you want it. Eventually, once the frames start selling, this motor mount design will be machined out of aluminum. Much less work for me.
'BrettMavriK
'BrettMavriK
Old 05-30-2009, 01:03 PM
skyliner skyliner is offline
i took a peice of 3/8th steel and drilled 4 holes to go through 2 to the motor and 2 to a u bolt then i took the bushings off a skateboard truck mounted them between 2 nuts going to the u bolt works perfect much less vibration and i can really crank down the nuts for a much tighter fitworks really well hope i was of some help will take pics soon just dont have a camera
if you dont see smoke your doin somthing wrong fly low beat the radar
04 shcwinn 80cc dax sbp camber cns carb boost bottle k&n filter 36 tooth 40mph (gps tested) havin fun and smokin scooters
Old 06-24-2009, 12:21 PM
backalleyminies backalleyminies is offline
a small heavy duty muffler clamp a 3eights x2and half long bolt weld the bolt in the center of the u on the muffler clamp put a shock rubber on each end of the bolt with a large steel washer on each end mount that part in the engine mount put the clamp on the frame
Old 06-24-2009, 07:43 PM
Isolated Motor Mounts
Urethane Bushings
Complete Adjustability
'BrettMavriK
'BrettMavriK
