Go Back   Motorized Bicycle: Engine Kit Forum > Bicycle Motor > 4 Stroke Bicycle Engines & Kits
4 Stroke Bicycle Engines & Kits 4 stroke motorized bicycle engine kits are great if you want reliability or do not want to mix your oil and gas. Learn from each other how to get the most out of your 4 stroke bicycle engine
Old 05-09-2009, 08:36 PM
Robert Robert is offline
Default need clutch help for Storm 49cc 4 stoke
I'm brand new to this,instructions have been misleading such as their listed one piece crank is actually sent as 3 piece and throttle attachment takes drilling a hole in bottom of handlebar when really its the top,all those kinks are worked out.........So problem is instruction tell me to disassemble my left side handle bar shifter to use as my clutch and shows I hook the opposite end to the left side gear box of my 4 stroke.I have thoroughly scanned my motor and it has no manual clutch lever to attach the wire to.Upon reading others threads over and over people state there 4 stroke is an automatic and since I don't trust these horrible incomplete instructions they gave I wonder if I ever needed to dissemble my shifter in the first place or for that matter manually pedal to 2 mph then drop the clutch or I'll wear out my clutch it said if not peddling it up to speed.Yes I did download the 4 stroke instructions I have checked 3 times.
Does anyone know if the 2009 Storm 49cc 4 stroke has an automatic clutch and I can forget the instruction,and so you know throttle is hooked up and ready,so clutch ,oil and gasoline is all I'm away from to start my bike.So if its an automatic then there is no need to pedal correct.Please me,Thank you
Old 05-09-2009, 09:09 PM
HoughMade's Avatar
HoughMade HoughMade is offline
Default Re: need clutch help for Storm 49cc 4 stoke
How about a link to the place you bought it or some pics.
I sense that there is a centrifugal (automatic) clutch as all 4 strokes I have seen (on the market) have one.
29/10ths cubic inches of raw power.
HoughMade at WIRED.com: http://www.wired.com/cars/coolwheels...memade_bicycle
Old 05-09-2009, 09:15 PM
HoughMade's Avatar
Is this it?
http://www.gasbike.net/bicycle-motor...torm-49cc.html
Yes, it has an "automatic" clutch.
...and it brings up a pet peeve of mine....I can count the number of frame mount 4 stroke kits on one hand (with fingers left over) and every retailer slaps their own name on the same old products as if it is unique to them.
Old 05-09-2009, 09:24 PM
your correct,they have only one 4 stroke and their instructions have so frustrated me,so if this is the case then do I still need to peddle bike up to speed as they say or do I just gently throttle from a standing stop.
Hough your bike is amazing,absolute stunning beauty
Old 05-10-2009, 08:54 AM
bobdirt bobdirt is offline
Robert, unless something has changed they have centifrugal clutch, no engager.
Very few of these gearboxes ie. hoot style last any lenth of time, sorry....
