Old 05-09-2009, 11:52 AM
mastafoo mastafoo is offline
Angry Bike will not move at all, Clutch locked
After I installed my new 80cc bike kit, I could drive around easily while the clutch was in the Neutral position. I actually almost got up to speed and started the motor. However, soon the clutch would suddenly lock and bring me to a halt. I cold somewhat fix this by moving backwards a bit and then moving forward. But now its stuck for good, and will not move regardless of the clutch position. This is my first build, and so far have not been able to run the motor. If anyone could help me, I would greatly appreciate it.
16:1 fuel
"red bat" 80cc china engine
clutch: Friction Plate / Dry
Old 05-14-2009, 10:02 AM
Norman's Avatar
Norman Norman is offline
LORD VADER Moderator
Default Re: Bike will not move at all, Clutch locked
I think if you will remove the cover that has the front chain sprocket under it you will find the problem. I think your chain has bunched up and is jammed see if that isn't the problem if it is not then let us know.
Norman
norms-iron-works.tripod.com
Old 05-18-2009, 05:20 PM
Sorry for waiting so long. Looks like you were exactly right! It was bunched up, and now everything works great, I even got the engine started. The chain is tighter now so that doesn't happen anymore. Unfourtunately, the whole engine moves to the side after driving a bit which makes the chain fall, and I'm working on that issue right now. I'm using the "big frame adapter". It has some rubber spacers between the washers, I might try taking those out.
Still, I couln't be any happier smelling those first puffs of exhaust!
Thanks again for the info...
Old 05-19-2009, 11:15 AM
Bikeguy Joe's Avatar
Remove the rubber if possible, and loosen the chain a little. 3/4" of free play is about right.
