Old 05-08-2009, 02:59 PM
MyrmidonJuan MyrmidonJuan is offline
Default Tooth Count
I have Bike Berry "80cc" that came with a 44 tooth sprocket...regarding chain fitment, can we basically use any tooth count? I ordered a 40 tooth without even thinking about whether or not 415 and 41 chains will fit.
Old 05-08-2009, 03:19 PM
2door's Avatar
2door 2door is offline
Default Re: Tooth Count
Yes your kit chain, 415, will fit the sprockets. The 40T will give you a little higher speed but the 44T will allow for better hill climbing. Think of it as gears in a standard transmission car. The bigger the rear sprocket, the lower the gear. Some guys run as low as a 36T in the rear and can get some awsome speeds but their ability to haul up a grade is reduced. The 40 or 44T is a good all around ratio for pleasure riding. Good luck, ride careful.
Old 05-08-2009, 10:38 PM
Thanks maaaan
