Go Back   Motorized Bicycle: Engine Kit Forum > Bicycle Motor > 4 Stroke Bicycle Engines & Kits
4 Stroke Bicycle Engines & Kits 4 stroke motorized bicycle engine kits are great if you want reliability or do not want to mix your oil and gas. Learn from each other how to get the most out of your 4 stroke bicycle engine
Old 05-07-2009, 08:53 PM
Large Filipino Large Filipino is offline
Default Titan Chain Adjustment simplified
I've been doing this it's just second nature of me when adjusting my chain on my Titan bikes
and I thought I would share how I do it.
You really can just eyeball it this carrier can run well even if it's off alignment a little but the way I'm demonstrating here would get your chain adjusted PERFECTLY.
I forgot to add that after you adjust the 4 sides check chain tension. If it's too loose then adjust
one bolt,measure,set then do the other three.
You want some play in your chain maybe 1/16 deflection or whatever. If your sprocket is not perfect you can get away with it even looser to compensate.
It's rather simple and a little romper roomish but it does the job.
I haven't had to adjust my chain on Cronus in a long time.
YouTube - Easy Titan chain adjustment
