re: can't find an answer then ask here someone may be able to help!!
Norman:
My clutch is making quite the racket! I had tried a couple different things from the get go since purchase. MY Motor-KingsMotor "80cc" 35T sprocket. I have the rubber on the outside of the clutch cover , I make sure there is only about a pea sized glob of grease inside.I had removed the pressure plate and had at one time replaced the clutch pads , since I have re-installed original's because it seemed the new ones wasnt grabbing either. but when I had removed the inner center plate spring and noticed the center nut was about 3-4 turns loose, so I hand tighten nut replaced clutch, cover. 1st test run, there is some serious rattling going on while clutch is disengaged! when under power/load it pulls good , has no slippage. the clutch right now is noisy. what about that center nut behind the pressure plate?
FileStyleCycles
Reason: mis spell
