Old 05-03-2009, 03:51 AM
datz510's Avatar
datz510 datz510 is offline
Default Build your own springer fork!
Found this link tonight.. really good tutorial on how to build your own springer fork for a bike! This one focuses on a build for a chopper, but could work for any bike. Best part is that it can easily be built to handle the stress of a motored bike.
brainfork
Old 05-08-2009, 11:33 PM
bugler1 bugler1 is offline
Default Re: Build your own springer fork!
Thanks for the link I my just have to try this.
Old 05-09-2009, 09:22 AM
Norman's Avatar
Norman Norman is offline
LORD VADER Moderator
looks good! nice find now I'll have to fire up the torch and get to work.
Norman
norms-iron-works.tripod.com
Old 05-09-2009, 10:58 AM
eDJ's Avatar
eDJ eDJ is offline
When we talk about springer front forks, there's always the question about what
springs. Yeah we can use valve springs off cylinder heads or go to the hardware
store and find some cadnium plated things from their assortment to build with.
Neat forks hugh ?
But the springs on these double acting springer forks will likely be "compression" springs
which have space between the coils.
Check this link out which explains coil springs.
Compression Spring Calculator - Engineers Edge
This link is to a supplier who can make custom stuff.
W.B. Jones Spring Company:springs manufacturer, coil, compression, torsion, extension springs
Look at springer forks like the Monark bicycle forks which use tapered ends and some
others where the coil spring has somewhat a barrel profile. The springs will be part of the eye
appeal and a focus area to the look of the forkset. Consider this when selecting your springs
expecially if you are considering a Boardtrack or Vintage build. But remember whether you use
chromium plated springs or painted ones, they will be a center of focus with those checking
your bike out. (judges at contest events too)
Old 05-10-2009, 12:11 AM
Goat Herder's Avatar
Gutter Rider
Somebody from Australia made a nice e-trike , with a homade set of these. I can't find the post anywhere I believe his name was Aussie Jester. It was one sweet ride anybody got a link?
Old 05-10-2009, 12:15 AM
Gutter Rider
Heres a utube link YouTube - 48 volt 20ah Electric Trike YouTube - Custom 48volt Electric Trike Overview Living life large from a wheel chair!!!!!!
Old 05-10-2009, 02:42 AM
POPS's Avatar
POPS POPS is offline
I watched his builds and he is a true craftsman!!! He built his own front end as per those instructions and than modded them for his own taste as he thought they were inadequate for his application. In the end KIM'S conclusion was he would not build another, and just buy one as the hassel, cost, and time did did not justify the end result...POPS
Old 05-31-2009, 02:14 AM
huckersteve huckersteve is offline
Looks like a challenging but potentially satisfying project! Thanks for sharing this.
www.firebellycycles.com
http://www.gohuckyourself.com
MY BIKES:
1978 Vespa Grande, 1984 JDM Honda Runaway
Firebelly Built 1985 Schwinn Sierra HT 67cc W/ Puch 50cc Cylinder Head, SBP Shift Kit, Pypelyne Exhaust, JNM Velocity Stack and Hi Flow Filter
STOP BUILDING MB's ON WALMART BIKES!! I MEAN IT. DON'T MAKE ME COME OVER THERE.
Old 06-05-2009, 10:08 PM
butchl butchl is offline
I'm in the process of building one of these to go on an old Simplex I modified. The tubing is Expensive now.
Old 06-28-2009, 10:25 PM
eomonkeyboi24's Avatar
eomonkeyboi24 eomonkeyboi24 is offline
looks cool, might try it.
