| Motorized Bicycle Trouble Shooting Use this area to post problems that may arise that you could use some help in figuring out what is wrong with their bicycle motor and what needs to be done to achieve top performance. |
05-02-2009, 12:03 AM
4 stroking at high revs
can a air leak cause this at high revs?
05-02-2009, 12:37 AM
Re: 4 stroking at high revs
i dont know,but you should check your bike for airleaks and seal them with gasket maker.
05-02-2009, 12:49 AM
Gutter Rider
lightly spray mist carb cleaner around the engine if the idle goes different anywhere than directly at the carb thats an air leak. A better exhaust pipe is what I think makes these motors go better. Along with port matching. Check your plug Its needs to be a chocolate brown or slightly golden . I go for the darker side don not like suprizes. If you are just running a new engine meaning not broke in go 16 to one for break in then 20-24 to one after it takes about 3 to 4 tanks burned before break in You will feel a slite bit more power after break-in.
05-02-2009, 11:17 AM
Four stroking is caused by an overly rich mixture. Move your needle clip up a notch and it should be better. You could also have too large of a jet.
05-02-2009, 11:39 AM
Good Morning Joe. That Is What I Think Also. When Adjusting Chain Saws, I Run It Full Throttle And Open The High Speed Needle Till It 4 Cycles And Then Turn It In Till It Sounds Rite. That Way You Avoid A Lean Situation. Ron
PUMP YOUR BRAKES  HAVE TO LOVE WINDOWS & THE INTERNET
NEVER BEAT ON IT, GET A BIGGER HAMMER
"A MAN WHO SAY`S IT CANNOT BE DONE SHOULD NOT INTERRUPT A MAN DOING IT"
05-02-2009, 04:54 PM
I learned the two cycle/four cycle thing from model airplanes.
02-28-2010, 03:03 PM
Where does one get different sized jets?
02-28-2010, 07:54 PM
You can solder it closed then re-drill it... I would try the C clip first.
| Thread Tools |
| Display Modes |
Linear Mode
