Old 04-28-2009, 08:03 PM
ElUnoSpeedy's Avatar
ElUnoSpeedy ElUnoSpeedy is offline
Default Spark plug skyhawk 48cc
Hello, im after a spark plug to suit the skyhawk 48cc, i bought a ngk bp6hs but found the thread too long, maybe its an aussie thing, the closest i could find was a ngk b5es, not sure if the numbers mean anything too but the thread length was the same, ta guys any info would be great..
Old 04-28-2009, 08:28 PM
Ghost0's Avatar
Ghost0 Ghost0 is offline
Default Re: Spark plug skyhawk 48cc
How did you determine that the threads were too long? Is it because the tip of the plug hit the piston or just because it was longer than the stock one?
Design is easy, execution the hard part.
www.sickbikeparts.com
Old 04-28-2009, 09:23 PM
Red face Re: Spark plug skyhawk 48cc
I just compared it to the original, and the threadn thickness was different too, wouldnt screw in, i am assuming that if it were longer it would hit the top of the piston, thats why the thread had to be the same length.
Old 04-28-2009, 11:00 PM
oylavabeer oylavabeer is offline
set the gap then reinstall , push the bike so the piston dose at least 1 revolution then pull the plug and check the gap that is what I did after my concerns regarding the same issue ( it runs fine )
Old 04-28-2009, 11:32 PM
Rayzor's Avatar
Rayzor Rayzor is offline
try the NGK B5HS...
i got the same kit as you and i run that, really smooth riding now, and a noticeable performance increase ove the stock autolites
Old 04-29-2009, 01:06 AM
Shadeslay's Avatar
Shadeslay Shadeslay is offline
NGK B5HS or B6HS depending on your climate. The 5hs is the cooler plug, 40-80 degrees, the 6hs is for 80-110 ambient temps "according too SBP"
Sun Tzu: To secure ourselves against defeat lies in our own hands, but the opportunity of defeating the enemy is provided by the enemy himself.
Old 04-29-2009, 04:15 AM
Thumbs up Re: Spark plug skyhawk 48cc
Ok thanks for the help, much appreciated..
Old 04-29-2009, 06:44 AM
Pablo's Avatar
Pablo Pablo is offline
Originally Posted by ElUnoSpeedy View Post
i bought a ngk bp6hs but found the thread too long, maybe its an aussie thing, the closest i could find was a ngk b5es, not sure if the numbers mean anything too but the thread length was the same,.........I just compared it to the original, and the threadn thickness was different too, wouldnt screw in, i am assuming that if it were longer it would hit the top of the piston, thats why the thread had to be the same length.
All the plugs mentioned - the BP5HS, BP6HS, B5HS, B6HS have EXACTLY the same threads and exactly the same thread length (depth 1/2")
A BPES WILL have too long threads (3/4")
Try this: NGK Part # key
So if you bought an ES and the thread length is the same as a HS, I would take the HS back for a refund.
