Old 04-27-2009, 01:11 PM
fistfulofsuss fistfulofsuss is offline
Default Does not go faster than 27mph after 4 tanks??
Any suggestions?? Wrapped my exaust w/ performance wrap, gotta performance air filter and installed a new spark plug "Champion" w/ out setting a gap.. Thought it would be fully broken in and I would be able to cruise @ 'round 30mph at helf throttle, any suggestions??
Old 04-27-2009, 01:26 PM
Retmachinist's Avatar
Default Re: Does not go faster than 27mph after 4 tanks??
The top speed is going to depend on what sprocket you are running. Are you running the standard 44 tooth that comes with most kits?
John
Old 04-27-2009, 04:47 PM
Bikeguy Joe's Avatar
That's about in the middle of the "top speed" of these things...25-35 mph.
Old 04-28-2009, 01:16 AM
Cabinfever1977's Avatar
my top speed i had it up to is 32mph,but even at 28mph it feels like my butt is strapped to a rocket on a broomstick.i wouldnt sugest this but you could take off your air filter and unscrew and take off the bottom of your muffler,you will get faster acceleration and top speed for a while but the effects on the engine are not know by me.you could up the gas/oil mix to 25:1 or 30:1 but the engine could seige if to low of oil.you could get cruiser or slick tires you will gain more speed.or you could get a smaller rear sprocket.
anyway i think 27mph is fast enough on a bicycle not built to go that fast.
the cruising speed for these things is 20-25mph
with ocasional speed increases to 30-32 for short distances
Old 04-28-2009, 08:03 AM
dvddtz's Avatar
dvddtz dvddtz is offline
Get a smaller sprocket for the rear wheel, and then like someone else on the forum likes to say"ride it like you stole it"
Old 05-01-2009, 11:41 PM
Tonycoretrainer Tonycoretrainer is offline
Try adding octane booster 1-2 ounces per gallon. It take a whole bottle for a car tank of gas.... It might increase the combustion!
Old 05-01-2009, 11:47 PM
these engines like regular gas and plain ol' 2-stroke oil.
not nitros, not jetfuel, or boostbottles or octane boosters but you can try it.
and set your gap on your plug while youre at it.
Old 05-02-2009, 11:20 AM
Octane booster is not going to do anything with a low compression engine.
Proper set up will.
But, the bottom line is that these engines are not race engines, and 27 mph is not to shabby.
Old 05-02-2009, 01:50 PM
Dave31's Avatar
Dave31 Dave31 is offline
As Godfather says, 27mph is not bad at all. On warm days I have trouble reaching 25mph. In the cool winter days I can hit 31 mph. My motor is very sensitive to temperature.
Old 05-02-2009, 03:54 PM
kallsop kallsop is offline
What wheel size, how many teeth on the rear sprocket, how many rpm's is the engine running?
My bike has a 26x1.75 tire, 44 tooth rear, and runs about 23mph at 5500rpm. Sure, it can rev a bit higher but the vibes start to get excessive. The speed is as read by a Schwinn computer and the revs are as read by an ENM PT16e2 rev & hour meter. I know it could go faster with fewer teeth on the rear sprocket, but we have big hills here and I don't want to give up the hill climbing ability. I'm not sold on any of the existing gear change products but eventually someone will crack that problem with a compact, reliable and fairly priced product. That's the holy grail.
