Old 04-23-2009, 08:47 AM
dudeman dudeman is offline
Default No Gas In Fuel Line and Lots of Vibration
I have a Grubee Gen II Engine with the Special Flange Mount Carburetor that mounts direct to the cylinder head. It runs but I can't understand why when I shut it off there is no gas in the transperent gas line. Be aware with this new carburetor mounting location the clutch cable stop hole in the case is right behind the carburetor fuel bowl and does't allow a good line for the cable to the clutch arm. Some more of that great engineering. It also has excessive vibration which I can't seem to cure with adjustments. Any help with these situations would be appreciated.
Thank You,
Dudeman
Old 04-23-2009, 09:42 AM
Bikeguy Joe's Avatar
Default Re: No Gas In Fuel Line and Lots of Vibration
Nothing you can do about the vibes....it's the nature of the beast.
As for the gas line- does the bike run o.k.? If so, keep an eye on it so you don't get a lean condition and maybe look for sources of fuel blockage (in tank screen, ect.)
Old 04-27-2009, 09:53 PM
bk_punisher bk_punisher is offline
what would be lean conditions?
Old 04-28-2009, 09:11 AM
spad4me's Avatar
spad4me spad4me is offline
An air leak between the carb and the engine.
A pinched or dirty fuel line, dirty Carb badly adjusted needle, that does not let enough gas oil mix into the engine. to properly cool and lube the internal parts.
Apply your choke while the engine is running.
Slowly, apply full choke.
Does the engine seem to run better at partial choke. BAD
Does it die at full choke when warmed up? GOOD
If the engine seems to run better with partial choke applied you have a lean condition. BAD
On mine the gasoline initially flows in a thin stream in the line then fills it up.
Old 05-02-2009, 07:52 PM
Cowboy Rider's Avatar
Cowboy Rider Cowboy Rider is offline
Hmmm...
My fuel line is never FULL either. Seems to run OK, except at the top end. At that point, it almost seems to be starving for fuel. I wonder if I should blow the fuel line out with air pressure in reverse to make sure there's no blockage at the tank. ?
Before: <}----------{> After:
~Scott.
Cowboy Rider's Bike Pics at Webshots
Old 05-23-2009, 07:32 PM
Road82 Road82 is offline
Squeeze the fuel line with your fingers below the fuel filter. Let go and you will see a trickle of fuel and some bubbles. Keep doing this till the fuel live fills up.
Old 05-23-2009, 07:40 PM
ebmvegan's Avatar
ebmvegan ebmvegan is offline
Thank You,
Dudeman
You may have to change the petcock as well. They're known for flow issues.
There is no moment like the now moment.
Old 05-25-2009, 03:38 PM
Norman's Avatar
Norman Norman is offline
LORD VADER Moderator
my fuel line does that too if it stops running and has fuel I use lung pressure to pressure up the fuel tank and go on my merry way don't do this with people standing around watching they will think your huffing gas and do not inhale doing this is a crude and rude way of doing something but it works. I hate to pedal the dang thing.
Norman
norms-iron-works.tripod.com
Old 05-25-2009, 10:44 PM
floridaboy's Avatar
floridaboy floridaboy is offline
I also have a Gen II engine and the same fuel line problems. My bike seams to run allright but the gas only trickles down the gas line and shows up in the last 2 to 3 inches. What do you all think of the low in power of your Gen II engines? Mine is leak and was told they were detuned to meet import standars. Trying to find what inprovements that i can make to boost the low end torque. If you know of anything that helps let me know.
Old 05-26-2009, 09:54 PM
Cabinfever1977's Avatar
that fuel line problem has nothing to do with your engine.
maybe the petcock or petcock intake filter?
or the float needs adjusting in the carb?
or maybe something up with your carb?
try a smaller gas line,i did and now i have no air in my line at all.
also a airleak will cause air to enter the line from the carb.
