Old 04-20-2009, 03:43 PM
manyguns's Avatar
manyguns manyguns is offline
Question Sprocket Installation Problem
I've run into a problem installing the sprocket on the rear hub. The center hole of the sprocket is 1 3/8" diameter, but the hub that it has to fit over is 2" diameter. How am I going to enlarge that center hole in the sprocket so it will fit on the hub? Anyone run into this problem? Do I have to get a different sprocket? I got my kit from DAX.
Thanks, Tom
Old 04-20-2009, 03:45 PM
freewheeling frank freewheeling frank is offline
Default Re: Sprocket Installation Problem
you will have to enlarge the hole. i did it with a die grinder, be very carefull and try to keep it as round as possible, frank
Old 04-20-2009, 03:49 PM
manyguns's Avatar
That's an awful lot to enlarge with a die grinder, isn't it?
Old 04-20-2009, 04:42 PM
yes it is ,you could take it to a machine shop if ya got the bucks or get a different wheel. all the sprockets i have seen are about the same size. maybe someone else can help more. look at all the sites here or maybe email dax he knows alot. frank
Old 04-20-2009, 05:14 PM
Cabinfever1977's Avatar
did you take the dustcap off your wheel hub?then check the size.
mark a 2" circle on the sprocket,centered
i would use a drill with metal bit and drill holes in a circle until the middle piece comes out.
then use a dremal to get the middle piece out.
Old 04-20-2009, 05:18 PM
manyguns's Avatar
Yes, I did. The hub itself is 2". I might try that.
Old 04-20-2009, 07:41 PM
Retmachinist's Avatar
If you are not an a big hurry you can send it to me. I will bore it any size you want for free. All it would cost you is the shipping. Or I can bore one that I have and ship it to you for just the price of the sprocket and shipping.
John
Old 04-20-2009, 08:26 PM
manyguns's Avatar
That's very nice of you. Let me check it out again tomorrow and I'll get back to you.
Thanks, Tom
Old 04-20-2009, 09:18 PM
hiker472's Avatar
hiker472 hiker472 is offline
I wish I came across this earlier......I would have sent you mine to do!
The way I did this was I first found something close to the size of the hub. Then after drawing it on the sprocket, I used one of those powered jigsaws and cut notches to my line, all the way around my drawn circle. Then I pried out a couple of pieces and went ahead and cut the circle out with the jigsaw. It was then that I used the die grinder and it came out really well.
Don't feed the bears....
Old 04-20-2009, 09:44 PM
a tomato paste can is 2" round.
