Old 04-18-2009, 05:44 PM
Nerevar Nerevar is offline
Default Clutch won't disengage! STUCK IN NEUTRAL!
I just got my engine back. Had it to the machine shop to get broken studs removed and new ones put in for the rear engine mount. When I got it back the clutch won't disengage, and it's making a grinding noise.
I took the clutch cover off and what I saw is in the attached images. The closeup image is with the spring removed.
Anyone know what's wrong? What parts I need? Also I looked at the inside of the clutch cover and it was all scraped up... it appears that the spring was rubbing against the cover. I don't know how the clutch works exactly so I don't know how to fix it. Any help will be greatly appreciated!
Thanks... I know SOMEONE here knows what to do!
Justin
ID:	7554   Click image for larger version
Old 04-19-2009, 12:02 PM
Dan's Avatar
Dan Dan is offline
Default Re: Clutch won't disengage! STUCK IN NEUTRAL!
there is a small screw that holds the "flower-nut" I can't see it in pics.
Norman posted this; http://motorbicycling.com/f30/motor-...lutch-301.html
I want 2 ride my bicycle
Old 04-19-2009, 05:33 PM
Banned
Dude, Your pressure plate is missing!!!
How did that happen?
Jim
Old 04-19-2009, 05:34 PM
Banned
Oh yeah, I forgot to mention, it also looks like your star nut is dinked up real good!
Jim
Old 04-19-2009, 05:37 PM
Banned
Ummm, what is that sitting at the bottom of the frame tubes in the first photo...It looks like the pressure plate.
Jim
Old 04-20-2009, 09:44 PM
Jim
Yeah, that's it alright... it got stuck there under the engine somehow and i couldn't find it. Ehhh... it's been a long work week.
Now I have a few new problems.
1. What is the correct way it is supposed to go together? Does someone have an exploded image of the clutch so I could get it put back right and properly adjusted?
2. Where could I get a new star nut if it needs to be replaced?
Thanks for the help!
Justin
Old 04-21-2009, 08:52 AM
Banned
Here ya go:
The cases look a little different than yours, (because this is a new engine I'm making), but the clutch assembly is the same.
Jim
ID:	7658   Click image for larger version
Old 04-21-2009, 06:13 PM
huckersteve huckersteve is offline
Here ya go:
Jim
What's that funny feeling inside of me? I'm all tingly, and kind of out of breath..
www.firebellycycles.com
http://www.gohuckyourself.com
MY BIKES:
1978 Vespa Grande, 1984 JDM Honda Runaway
Firebelly Built 1985 Schwinn Sierra HT 67cc W/ Puch 50cc Cylinder Head, SBP Shift Kit, Pypelyne Exhaust, JNM Velocity Stack and Hi Flow Filter
STOP BUILDING MB's ON WALMART BIKES!! I MEAN IT. DON'T MAKE ME COME OVER THERE.
Old 04-21-2009, 08:01 PM
wow, thanks Jim... that was EXACTLY what I was looking for. You didn't just make that image up did you? You're pretty good if you did. Anyway got the clutch together and its working properly finally.
