Old 04-18-2009, 03:59 PM
huckersteve huckersteve is offline
Default What have I done?!?!
Well, I've finally gone and done it- I went crazy and ordered a butt-load of equipment for a fresh motor bike build. (My bike recently having been stolen, it was time to go for the gusto.)
So I ordered the following:
Gasbike.net 67cc Black Stallion Motor kit (Comes w biggie 2.5L tank)
Sick Bike Parts Standard Shift Kit (shifty gears!)
SBP Performance Air Filter (higher flow in)
SBP Expansion Chamber Exhaust Kit (back pressure and loudness!)
SBP Carb O-Ring (better carb seal on intake)
SBP 67cc Thin Head Gasket (increases Compression)
SBP High Efficiency Plug Wire (increases spark quality)
SBP Heavy Duty Front Freewheel (made by White Bros.)
SBP 11 Tooth Primary Drive Sprocket (increases top end)
SBP Fancy NGK Plug (better spark)
Manic Mechanic Clutch Actuator Kit (better feel, pulls from stops!)
SBP Engine Hardware Kit (grade 5 or better bolts for entire engine case)
Yeah, so that added up to quite the pretty penny! (Cool side note- we also ordered a Grubee motor for my one buddy and clutch kit for my other buddie's rigs at the same time!)
Now for the donor bike:
She's a 1984 Schwinn Sierra MTB. True Temper Chromoly frame, six speed rear freewheel, and O.G. "Bullmoose" handlebars. The bike is all original except for a retrofitted RST suspension fork. On this Pre-suspension Schwinn, a fork choppers out the HT angle a little for the worse, but that may equal out a bit with the added heft of the motor in-frame, and at speed, we'll see..
It's a quality old bike, in cream puff condition, and I believe the old school six speed rear freewheel and heavier gauge chain will be a perfect match for the SBP shift kit. My only qualm right now is I'm not in front of the bike at this moment and can suddenly not remember if it has a euro bottom bracket or an American one, and I'm just not positive if the SBP kit will come with what I need to set it up on either/or. I will worry about that when I get to it.
Anyhow, she's intended to be built up with a rear cargo rack and full coverage fenders, as well as knobby tires for some back roads/fire roads exploration. She'll be a spendy build when I'm done, but I figure why do this from scratch unless I can just do it up right?
Anyhow- there's my story! Can't wait to get my parts, I'll post pics of the donor bike tonight and when things start to arrive, update from there! What do you guys think about my little plan?
Cheers!
-Steve
www.firebellycycles.com
http://www.gohuckyourself.com
MY BIKES:
1978 Vespa Grande, 1984 JDM Honda Runaway
Firebelly Built 1985 Schwinn Sierra HT 67cc W/ Puch 50cc Cylinder Head, SBP Shift Kit, Pypelyne Exhaust, JNM Velocity Stack and Hi Flow Filter
STOP BUILDING MB's ON WALMART BIKES!! I MEAN IT. DON'T MAKE ME COME OVER THERE.
Old 04-18-2009, 05:48 PM
lordoflightaz's Avatar
lordoflightaz lordoflightaz is offline
Default Re: What have I done?!?!
Did you mention to Manic Mechanic that the Clutch Actuator Kit was going on a SBP kit? I seem to recall that he has a special one for the SBP kit.
I would have ordered the engine from someone else. Do an inventory when you get it and check for damage. Luckily you won't be using the muffler or chain guard, so you don't have to worry about them being dented and scratched.
Sounds like you are gonna have some fun.
Map your motorized bikes location on a Frappr Map show us where you are and post a pic of your bike.
If trailer parks didn't exist would tornadoes exist?
Old 04-18-2009, 06:39 PM
I did NOT know there was a SBP compatible clutch kit- hmm.... I'll try emailing them to see if I can change the order. Hopefully they will get it before anything ships out on Monday. Thanks for that heads up I appreciate it!
Sounds like you've either had a bad experience with Gasbikes.net or know someone who has. I guess we'll see how they do...
MY BIKES:
Old 04-18-2009, 06:47 PM
Just emailed him, thanks again. Both SBP and Manic Mechanic are replying to emails today (good weekend service guys- THANKS!) so hopefully I'm in time to resolve a potential issue here..
MY BIKES:
Old 04-18-2009, 07:43 PM
Reply from James at Manic Mechanic received- change noted and shipping out Monday. SBP ships Monday too! Looking good for starting to build on Wednesday!
MY BIKES:
Old 04-18-2009, 11:16 PM
Readin' these forums all the time I retain useless info, I guess the clutch thing is not useless, since I would need to know that if I bought one for the "Blue Bike".
I have purchased something from them and I sure hope the motor don't break before the warranty is up. I have not modified that engine at all. It is still as purchased. I am following all the break in procedures which should be completed in the next week or so. (You read it here folks so it must be true.) When I think of them I think of "Throw" And "Trust"
Old 04-18-2009, 11:25 PM
Cabinfever1977's Avatar
i ordered from gasbike.net and nothing was scratched or dented except my clutch cover had a couple of small tiny defect dings.my muffler is perfect paint and all.my chain guard is perfect too but its not on my bike yet.my engine is good too.
Old 04-18-2009, 11:47 PM
Good to hear. I'm sure the motor will be fine
MY BIKES:
Old 04-19-2009, 01:47 AM
I'm happy for you
Old 04-19-2009, 09:15 AM
NunyaBidness's Avatar
NunyaBidness NunyaBidness is offline
The only thing not on your list that would have to be on my list, if I had the money to do a build like that, would be one of Jim's motors that he is doing. You will see what I'm talking about from Jim's post here http://motorbicycling.com/f13/transf...html#post63786
Imagine that engine with your list of parts on that bike.
