Old 04-15-2009, 08:23 AM
midatlanticcycle midatlanticcycle is offline
Default erratic/no idle
i suspect this idle topic has been beat to death here but since i'm a newbie, thought i'd ask anyway. my kit is 80cc. go fast chinese job, exactly like bike berry, gas bike, and most others offer. bike runs great for what it is, minimum amount of fiddling necessary to keep it running. but idle is all over the place and i know there's only speed adjustment screw, no mixture screw. carburates pretty well thru rest of operating range. what is going on here and any solutions? fuel fresh, plug fine, no air leaks i know of. is it mismatched intake gasket, something i'm missing? any help much appreciated
Old 04-15-2009, 09:41 AM
rmeloy34's Avatar
rmeloy34 rmeloy34 is offline
Default Re: erratic/no idle
still sounds like an airleak to me...check your fuel hose,I was getting leaks there,I replaced it with 3/8 Tygon a little tight going on but it works great.
also check your float
Its often easier to get forgiveness than permission!!....Rob in CT
The First Harleys had pedals!!
Old 04-15-2009, 10:29 AM
Bikeguy Joe's Avatar
Air leaking somewhere fo'sho'.
Old 04-16-2009, 10:15 PM
i'm going to do the intake gasket mod, reseal it, install new carb this weekend i got online. and fiddle with it some more. thanks for the help guys.
Old 04-16-2009, 10:24 PM
Finfan's Avatar
Finfan Finfan is offline
Get yourself some oil resistant Permatex (I forget which color that is), put a bead of it on your intake and remount the carb. Most air leaks happen because it is hard to get that point properly sealed.
Edit: http://motorbicycling.com/f30/instal...cycle-303.html
-and-
I'm not lost, I'm exploring!
Old 04-17-2009, 01:00 PM
Cabinfever1977's Avatar
or you could use gasket maker.
