Old 04-14-2009, 09:15 PM
FlyJSH FlyJSH is offline
Default Clutch adjustment - slips when hot
Howdy all,
I have been adjusting my clutch, but am still having some trouble. On a cold engine the adjustment is fine, but as it heats up, the clutch slips (not so much when it is underload, rather it slips when trying to restart). If I tighten the clutch more, it doesn't fully disengage when cold. Any suggestions?
Thanks,
J
Old 04-15-2009, 09:31 PM
europorsche914's Avatar
europorsche914 europorsche914 is offline
Default Re: Clutch adjustment - slips when hot
thats odd i have always had the opposite problem with my clutch slips when cold, wont disengage when hot... found out my clutch pads had glazed over and some brake cleaner solved it. Now works properly. Other than spraying down the clutch pads w/ brake cleaner, dont know what else you could do, I have never heard of it happening the way you describe. Let me know how it goes -Justin
SOLD..50cc Morini S6-T 5.8hp,
44 tooth sprocket, Early 1990's Diamondback Frame, 26" WTB FX28 Wheels w/ Shimano XT Hubs,
Dellorto PHBG Race Edition 19mm Carburetor, 4 Valve Reed Intake (combined adds ~2hp),
Homemade Expansion Chamber, Homemade Steel Pack Muffler, Homemade 1.6 gallon Rear Gas Tanks
TOP SPEED: 54.0 MPH (not gps tested yet)
Old 04-16-2009, 07:49 AM
Bikeguy Joe's Avatar
http://motorbicycling.com/f3/externa...ring-4851.html
Also, clean the pads with some brake cleaner.
