Old 04-13-2009, 09:29 PM
hello hello is offline
Default i need help my bike wont start
my bike wont spark when i try to start. it leaks oil out of the muffler after i try toget it started. ive changed the spark plug and checked the wireing can some body help me
Old 04-13-2009, 09:56 PM
Dave31's Avatar
Dave31 Dave31 is offline
Default Re: i need help my bike wont start
Welcome to the forum, glad you joined us.
Have you had it running before?
Try to disconnect the kill switch and give it a go.
Old 04-13-2009, 11:17 PM
Cabinfever1977's Avatar
how long did you have it?and how much did you use it?
Old 04-14-2009, 12:01 PM
Goat Herder's Avatar
Gutter Rider
I your getting a lot of product out of the exhaust pipe carb bowl over flowing? Need more info.. What is your fuel/oil mix? Does it have spark when you ground the spark plug to the head and turn the motor over? More info please..
Old 04-20-2009, 01:54 AM
BrassoMan's Avatar
BrassoMan BrassoMan is offline
Unhappy Re: i need help my bike wont start
Hi, I think I have the same problem as him. When i try and start the engine, all I feel is the vibration of the piston moving up and down with the occasional cough. There is also a bit of blacky brown oil leaking from the exhaust.
I have checked and I am getting a spark.
I have not started the engine before, i have just installed it. I am using unleaded 95 or something rather with 2 stroke oil.
Any help would be appreciated. Thanks
I just went and rolled down a hill with the clutch engaged, the engine was noticeably warm suggesting that there was combustion.
Old 04-20-2009, 02:09 AM
DEATH4OF4's Avatar
DEATH4OF4 DEATH4OF4 is offline
Check The Fuel Mixture. If Its Not Broken In Use 16:1. Check The Carb For Leaks Around The Intake Manifold. Use A Ngk Plug With Proper Gap + Use A Better Plug Wire. If Its Dripping Oil From The Pipe You Probably Got To Much Oil In The Gas. Hope This Helps
I Don't Know Everything...but I Know What Works.
