Re: Honda GXH50 Fuel Pump Install
I think that the crankcase breather is required by the EPA?
The breather tube connection in the air cleaner has a restriction in it, so crank case pressure on the down stroke pushes on the diaphragm in the hockey puck pump. Then the pressure bleeds out into the intake air stream and any oil / gas fumes from the crankcase are burned in the engine.
Anyway, that is my take on the fuel pump.
I would assume you could prime the pump and the fuel line by blowing / sucking ? on the hockey puck line that normally goes to the crankcase breather.
An other solution would be a an inline primer bulb line is part of weed wacker engines.
Jim
Easy does it, but do it!
Reason: add information
