Old 04-09-2009, 07:51 PM
Sidthekidd11 Sidthekidd11 is offline
Default carb Idle screw..help
hey i lost the crb idle screw and know i can buy a new one but i dont want to wat for shipping and all that so i was wondering if any knew the size of the screw so i can try to use that and put a pen spring on it.
any other ways we be helpful too.
Thanks, Mike
Old 04-10-2009, 01:28 AM
skjjoe's Avatar
skjjoe skjjoe is offline
Default Re: carb Idle screw..help
thats dax has them
Old 04-10-2009, 06:05 AM
commander's Avatar
commander commander is offline
Its a simple metric threaded screw , I know a 10 mm wrench fits the head if it were a regular bolt. But try a few metric sized bolts till you get one to thread into the carb.
Once you have found the correct threaded bolt, just simple grind the head to a cone shape , add a small spring to it and you have yourself a new ideler screw.
If you tend to loose your idle screw alot, then use a short cable lead from your fishing tackle box and wrap it around your idle screw so it stay in place, then find a nut or bolt some where to locate the other end , so that if it works its way loose again it will still be tied to the engine by the cable you just added and then you can simple reattach it .
For when it is to rainy and cold outside to play with my bike .
I go here
Old 04-10-2009, 08:28 AM
thanks guys
Old 04-10-2009, 09:25 AM
Norman's Avatar
Norman Norman is offline
LORD VADER Moderator
idle screw size anyway here is what I found.
thread size .7mm
length not counting the head of the screw is 11/16" long
the end of the screw is not threaded for about 3/16" and there is a about a 45 degree angle on the end.
spring is about 3/8" long uncompressed and the inside dia. about 3/16"
you should be able to get the parts at a hardware store or nappa auto parts store.
Norman
this picture might help
norms-iron-works.tripod.com
Old 04-10-2009, 10:08 AM
commander's Avatar
Norm, you are so much better at explaining what i mean to say . LOL
I go here
Old 04-10-2009, 10:53 AM
are you able run the bike with out the screw ...just temporarily
Old 04-10-2009, 11:45 AM
theonlyhek's Avatar
theonlyhek theonlyhek is offline
No way mon
Old 04-10-2009, 11:46 AM
ok so thats out of the picture i guess
Old 04-10-2009, 01:25 PM
Norman's Avatar
I added a picture of the screw.
