| Motorized Bicycle Trouble Shooting Use this area to post problems that may arise that you could use some help in figuring out what is wrong with their bicycle motor and what needs to be done to achieve top performance. |
04-09-2009, 09:45 AM
Blew exhaust gasket
I installed a thick exhaust gasket from Dax and it blew out in only a month. The bike seems to be a lot quicker, though, with all that exhaust bypassing the muffler. Any problem just using some gasket maker in a tube?
04-09-2009, 11:35 AM
Re: Blew exhaust gasket
You'll want something that will withstand 1000 degrees F.
Several layers of aluminum foil will work in a pinch.
04-09-2009, 03:48 PM
Custom Builder / Dealer
Use a old school VolksWagen heat riser gasket!
04-09-2009, 05:35 PM
Gutter Rider
Way cool I've used the foil in a pinch. What does the heat riser look like I mean does it have a matching bolt pattern . That would be the bomb then
04-09-2009, 05:59 PM
I was wondering if those would work. I have a few kicking around. Thanks for clearing that up for me!!.
04-09-2009, 06:05 PM
Yahoo! Image Detail for http://www.csp-shop.de/shop/images/artikel/13196.jpg
Usually there are a pair of these in a muffler replacement kit but (clamps, gaskets and hardware) Anyone who has a dual carbs on their old aircooled VW probably wouldn't need them. So there are usually plenty of these around in an aircooled VW shop. I am sure I have several. Good quality too.
04-09-2009, 06:25 PM
Check out these copper ones, MANIC Mechanic Parts.htm ,under miscellaneous.
04-09-2009, 08:18 PM
im lucky my kit form gasbike.net came with 2 of everything,extra gaskets,studs,mounts,sparkplugs,caps,chain link,idle set screw,
make a gasket out of something(rubber) and use gasket maker.
04-09-2009, 08:28 PM
You don't mean rubber on the exhaust do you. It will never take the heat. Not for long anyway.
John
04-10-2009, 02:41 AM
i picked some stuff up at advanced auto for 5 bucks it came in a roll .i think its some kind of fiber. i cut up three gaskets ,put them together and have not had a problem yet.i'll try to see if i can find a link.
| Thread Tools |
| Display Modes |
Linear Mode
