Old 04-09-2009, 08:36 AM
waterdamage waterdamage is offline
Default clutch prob
hey guy 1st build and my clutch is slipping the cable dos not have any tensionon it ho do i adjust the clutch?
Old 04-09-2009, 08:59 AM
Venice Motor Bikes's Avatar
Venice Motor Bikes Venice Motor Bikes is online now
Custom Builder / Dealer
Default Re: clutch prob
Hi,
Take off the big cover on the right side of the engine.
You will see a 'star' shaped nut in the center of the clutch... take out the tiny set-screw that keeps it from turning, then tighten the 'star' nut 2-'clicks', NOT 2 TURNS!!! Then test to see if the clutch is grabbing. Keep tightening it one 'click' at a time until it works good.
Once it works, put the set screw back in & the cover back on...
