Old 04-08-2009, 04:54 PM
Norman's Avatar
Norman Norman is offline
LORD VADER Moderator
Default lights that run off the white wire no battery needed
This light is for the china engines and it works off the white wire.
here is some pictures and information on the lights: The head light comes with the wiring and mounts, A micro switch turns both the head and tail light on/off.
The headlight comes unpainted (died black) The mount fits 1" dia handle bars to mount on 7/8" dia handle bars use the 7/8" inserts included .
Instructions included with the head light
Headlight with mounts is $40.00 includes shipping.
Head light with mounts and tail light $55.00 includes shipping
tail light only is $20.00 includes shipping
Payment for lights by money order or PayPal . paypal address is nleonard52@cableone.net
I ship by USPS.
Some important info: Some engines have a magneto coil that just isn't the best there's been a few that are not up to the task of running these lights unless you keep the rpms up at idle or the engine will die at the normal idle.
The tail light is dim or will not light up at idle on most mag coils,above idle the led light will be bright enough to be seen from behind.
If you want to be able to see in the dark and be seen from behind when riding then this set up should work fine plus no need for a battery.
WARNING!! Your engine may not work with this light at all or you may have to increase the rpm so it will idle it may also run crumby when the light is turned on. Seems that in trying to make these engines cheaper they've skimped on the mag coil windings and the mag rotor strength. I can't tell how good or sorry an engine will be no matter who made it or sells it so, I won't refund your purchase so please check you engines white wire system first.
You can test your mag coil with a 6 volt lantern bulb, do not get the led bulb it will not work for this test( you can get a 6 volt lantern bulb at Walmart) if the engine will run with it and idle well then the light I sell should work fine. solder 2 wires to the bulb, one to the bulbs center terminal, the other to the bulbs side, attach one wire to the white wire the other to the engines ground doesn't matter which wire is used for the ground or vise versa as this is only to test the engine's ability to light the bulb. If the bulb lights and doesn't kill the engine then my light should work, if it dies, try it again and see how high you have to set the idle. If it will work with a higher idle, you will need to decide if you want your engine to idle that high before you purchase this light. Once you've bought the light there's NO RETURN OR REFUND... the other option is.The lights will work with a 6 volt battery.
Fairracing does a review on the small light below on the next post (old style housing) new light has the same lighting as the old one just a newer style housing and mount for the new light.
contact me here by PM for more info. or email me. norms-iron-works@hotmail.com
Norman
norms-iron-works.tripod.com
Old 04-12-2009, 11:48 PM
Dave31's Avatar
Dave31 Dave31 is offline
Default re: lights that run off the white wire no battery needed
http://motorbicycling.com/f3/normans...html#post72801
Old 05-04-2009, 12:12 AM
Dave31's Avatar
Here is a short video I made with my camera on the curb and me riding towards it so you can see how bright Normans Headlight is, keep in mind this is the small light.
Light pictures by FR31MB - Photobucket
Old 05-04-2009, 11:16 PM
Ilikeabikea's Avatar
Here are some pics of Norms lights. The two toward the garage are the small light about 40' away.
The two toward the fence are the big light about 40' away. They are a little fuzzy because it was so dark outside. I used a tripod but the wind was blowing pretty good and couldn't get the camera real still................
ID:	8139   Click image for larger version
ID:	8140   Click image for larger version
ID:	8141   Click image for larger version
Old 05-05-2009, 12:43 PM
Norman's Avatar
Ilikeabikea's pictures are as follows in the above post. light is on looking in garage#2 then lights of you can just see the Harley if you look closely. #3 picture is lights off then # 4 picture is lights on 50' to the fence we can't get the camera to really show the lights brightness. It was cold and over cast at night around 9:30PM and the ever blowing Texas wind.
Any way no batteries needed for this light the white wire will work good.
I've been running all my bikes with this light my first bike is now 2 years old and on the same bulbs. You can run it off batteries if you want to I haven't but the headlight and taillight will run off batteries. ( batteries not included) or needed
Norman
Old 05-16-2009, 10:51 PM
vcm1376 vcm1376 is offline
I am using one of Norman's lights and I am very pleased with the quality. The light is plenty bright and works flawlessly. I wanted to start riding my bike to work to save gas so I decided to see how long it would take to get there. It was after dark, no problem, I have a light. I went there and back, passed by several police cruisers and none of them stopped me. I'm very happy with my light.
Old 05-23-2009, 09:55 AM
Norman's Avatar
I did some checking into shipping by the USPS.
To ship to the land of OZ its about $15.00 but I can put in maybe 3 headlights in the box, so if you guys want to try one of my headlight I'll be willing to ship you one or 3 or more.
Same for any country I can box up what you want take it to the post office and see what it will cost for the shipping then contact you about the price.
You will only pay the extra price on the actual shipping. Most of the time your light will get its first ride on a Harley Davidson might give it an attitude or something I don't know.
Norman
Old 05-26-2009, 08:09 PM
Goat Herder's Avatar
Gutter Rider
Just got Norms light in It looks way cool . I got the one pict above with the skull cap . I will be playing with it tonight. Nice job on the skull cap Dude! Now I have to come up with a slick mounting Idea for the rear.
Old 05-28-2009, 12:36 AM
OzzyU812's Avatar
OzzyU812 OzzyU812 is offline
Man, I cant wait for mine! I haven't checked this thread for a while. Norm your getting good with those woody effects!
7/8 mount I believe, Its wally type bike and the Schwinn grips fit.
Hope you like the package! Read instructions on back or you may cut the money order.
DAX 80f
Slanthead
NGK B7HS
SBP performance wire
44T
Stock Exhaust
32:1 cheap oil
no port matching
30 mph uphill!!!
Old 05-30-2009, 01:19 AM
Gutter Rider
Got my lights working today. Plenty of light too. They work great ! Found out they worked with my direct hit spark plug attachment perfectly!
