Old 04-03-2009, 06:24 PM
hibernaobscurum hibernaobscurum is offline
Default Centrifugal clutch/pull start pedal clearance problem
I was wondering if anyone knew where to get a wider one piece crank. I've looked and I can't find one anywhere. Or as an alternative, I wanted to know if its possible to mount the engine higher in the frame so that the engine is higher than the pedals and how to do that. I have the room to mount it higher, I'm just not sure how to do it.
Old 04-03-2009, 06:37 PM
TigerToothBikes.com's Avatar
TigerToothBikes.com TigerToothBikes.com is offline
UK Dealer
Default Re: Centrifugal clutch/pull start pedal clearance problem
i have used spacer washers in the past, but do so within reason considering stress factors etc.
For EU and UK Kits/Parts/Fully fitted bikes.
Visit us at
www.TigerToothBikes.com -
'Engines Ignited By the Finest Cigar'
"Tigertooth built him a jet
When his parts come in he'll be set
The pulse was so cool
It'd make a guy drool
He'll put one on a bike now I bet....................." - Ilikeabikea
Old 04-03-2009, 07:37 PM
Could you provide a picture? So I can see how you did it.
Old 04-04-2009, 03:45 PM
Cabinfever1977's Avatar
i have the same problem,but i cant move my engine no higher.
my kit came with a wide 3 -piece set but my bike uses a 1 piece.
you can use a crank and peddals from a 20" kids bike or they have a converter for the 3-piece wide set so it fits the 1 piece hole,but it cost more money.
Old 04-08-2009, 09:28 AM
Dan's Avatar
Dan Dan is offline
Spooky Tooth has one pc. cranks in 4 sizes.
Spooky Tooth Cycles - Motorized Bicycles: Gas Powered and Electric Bikes - 1 Piece Steel Ashtabula Crank
I want 2 ride my bicycle
Old 04-24-2009, 07:19 PM
i got some exercise bike short crank peddals and put on my bike and they work perfect.
