Old 04-03-2009, 02:01 PM
supasamurai supasamurai is offline
Default Hello from the Big Easy
Hi there, I just put my kit together the night before last and have ridden about 2 hours already! I got my git from boygofast and everything seemed to work just fine, although there are some hiccups. When I'm coming to a stop, I pull in the clutch and while the engine seems to slow down a bit, it doesn't return to idle, it just kind of races like that till I let go of the clutch again. I've been using the kill button when I get close to a stop sign to keep it from racing. Any ideas? Also, I'm getting air bubbles in my gas line. Whats up with that?
On another note, the day I put my wheels to the road for the first time, I see another one parked out on the street! Getting rained on, no less! Does the rain hurt these things?
Old 04-03-2009, 08:32 PM
wheelbender6's Avatar
Default Re: Hello from the Big Easy
Welcome to the forum.
High idle can be an air leak on the intake side or a throttle cable binding. Search the forum about those things. Somebody here has solved the same problem.
Air bubbles in the gas line is a leak of some sort. Try to clamp the ends of the flexible fuel line onto the fittings.
Good luck.
Old 04-03-2009, 10:02 PM
Dave31's Avatar
Dave31 Dave31 is offline
Old 04-06-2009, 11:39 PM
Apparently I hadn't been setting my petcock to open fully. Still haven't gotten the carb to calm down. It's just racing when I let go of the clutch.
Old 04-07-2009, 02:41 AM
Goat Herder's Avatar
Gutter Rider
Welcome to the forum lots of great advice , Ideas here! Make sure you don't have a air leak if its the china two strock it will hurt it not enough oil. Check your gasket at the in tack manifold?
Old 04-07-2009, 08:57 AM
I got it! I had like 3/32's of the end of my throttle cable not fully inserted in the carb. Woops! My cable goes through a hole in my frame so things get a bit tight there.
Thanks for the help guys!
