Go Back   Motorized Bicycle: Engine Kit Forum > Motorized Bicycle > Pre-Motorized Bicycle Information.
Pre-Motorized Bicycle Information. Before you mount that engine to your bicycle frame, you'll want to know if the bike is ready for the engine! Ask our experts here for advice on what motorized bicycle engines perform well on what bicycles.
Old 04-09-2008, 01:37 PM
ran49's Avatar
ran49 ran49 is offline
Default Rim to tire fit
Right now I'm running on 26x2.125 tires.I'm thinking if I replace these I might drop down too a slightly thinner wheel.Is it possible to use a thinner tire on the existing rims.Thanks, Ron
Old 04-09-2008, 02:07 PM
deacon's Avatar
deacon deacon is offline
minor bike philosopher
Default Re: Rim to tire fit
yes. your rim is most likely not that wide. I took 2.125 tires off and run 195 now. Same rims... I also run 195 on rims that had 175 tires.
Old 04-09-2008, 04:05 PM
Bikeguy Joe's Avatar
Yes. They should be fine.
Old 04-09-2008, 04:36 PM
ran49's Avatar
Thanks guys
Now lets say I wanted to switch from 14Ga.spokes to12Ga.Can rim and hub be drilled out to fit.Also any good place to look for tires.Ron
Old 04-09-2008, 04:39 PM
Big Joe Big Joe is offline
Also is there a good place to get complete wheel with 12 gauge spokes or send wheel to get 12 gauge spokes installed?
Old 04-09-2008, 04:41 PM
deacon's Avatar
I buy my tires at wallymart but I have a room full of used ones as well so im not good to ask. yes you can use your rims and hubs most any bike shop will do it for you. or you can try I guess.
Old 04-20-2008, 09:32 PM
HoughMade's Avatar
HoughMade HoughMade is offline
How wide are your rims? I have always run 26x2.125s, but my old rims were 1.75" wide (and worked fine). My current wheels have a 2.125" rim (and 11 ga spokes).
As for drilling the hubs and rims, a switch to 12 ga is pretty standard so a decent shop should be able to take care of that including drilling.
29/10ths cubic inches of raw power.
HoughMade at WIRED.com: http://www.wired.com/cars/coolwheels...memade_bicycle
